![]() Join Date: Dec 2007
6.0L 4L80E in my 1970
Gents,
I can get a decent deal on a 2007 6.0L with a 4L80E trans with less than 100 miles, not 100K, 100. Does anyone make a harness for this engine, or am i going to have to go with a 2005? The guy selling it has the complete harness and ecu. Rigo |
Re: 6.0L 4L80E in my 1970
speartech.com
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
![]() Join Date: Aug 2004
Search for Shifty's posts on Gen3 conversion info. There's a ton of good stuff there.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#4 | |
Thread Killer!
This should be the Conversions & Hybrids section. I think you will find a similar thread for shiftty there also. speartech.com comes highly recommended from the LS1tech.com people, he is a very active board sponsor. Hope this helps!
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
I have looked at all of the vendors that sell harnesses. I am waiting on a response. I was wondering if anyone here had done this conversion already and had insight on the whole process. I may have to break down and get an older eng/trans combo.
2007 6.0 with less than 100 miles on it! Dang it! I want it. |
Active Member
![]() Join Date: Jul 2007
My .02
Depending on the deal you're getting, I'd say buy it. With 100 original miles, you can always sell the engine and trans if you can't get a wiring harness for it. |
What is wrong with the 05 it sounds like you have a line on?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
![]() Join Date: Jun 2002
Call John at Speartech, I'm sure he can hook you up, or at worst, use an earlier computer (which he has) youl want to use one of his custom harness anyway, so you can hide the computer.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
The 05 has 35K on it and its only 800 less.
I am calling John @sparetech tomorrow first thing. Thanks guys for all your wisdom. This board ROX |
DO IT!!! If I can figure this stuff out, ANYBODY can. Learned most of what I needed to know right here. See these:
http://67-72chevytrucks.com/vboard/s...d.php?t=244448 http://67-72chevytrucks.com/vboard/s...d.php?t=195643 http://67-72chevytrucks.com/vboard/s...d.php?t=269754 and my own shameless plug... ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=287015 The wiring seems intimidating until you tear into it. A good set of diagrams and a little encouragement was all it took. It's harder to make the harness LOOK good than it is to make it work. By modding the stock harness, you can route it where ever you want AND you can gloat about doin' it yourself, not to mention saving a few hundred bucks. Good luck with which ever way you go! E~ |
ok, that makes sense, why do you want such low miles??
![]() Join Date: Apr 2005
Lots of good info on here. I'm putting 5.3/4L60E in my 69 Burb and my 67 4Door Crewcab.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
