Hood
Help!!!!!!!!!!!! can anyone help me with my hood it keeps popping up in the back near the cowl not much maby an inch and i dont know how to fix.
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Re: Hood
Try some PB blaster on the rivets & all pivot points on the hinge. If you can push down on the rear of the hood and it closes properly flush then your hood should be close to correctly adjusted. If not readjust & lub. If that don't work might be time to replace them. Work them well after lub. That & door hinges are commonly forgotten.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Hood
I know this has been discussed in the last few months. I forgot the posting, but I'll try to find it because I NEED DIRECTION AS WELL!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 05-19-2008 at 06:05 AM. |
Re: Hood
Your gonna need new hood hinges, the rivets wear down after 40 years or so. They arent too expencive.
Re: Hood
My 72 did that.Somebody on here said to loosen the hinge bolts on the fender and open the hood as far as it will go.That worked for me you might want to try that.
77 swb starting all over again. |
its all about the +6 inches
Re: Hood
