Pics with 67-72 C-10s pulling a car trailer or a boat?
I am looking for pics with 67-72 c-10s pulling a car trailer or a boat. With rear coil springs are even better. I noticed on my 69 c10 when I am standing on the tailgate rear end drops about 8-10" and I weight maybe 170lbs. I am trying to see if I have enough truck to tow. Thanks
Re: Pics with 67-72 C-10s pulling a car trailer or a boat?
That seems like a lot of drop for 170 lbs. Here is a picture of a C-10 with a complete cab in the bed which weighs over 500 lbs. and it did not drop that much, (it has the original rear springs in it in this pic).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
No pics.But,I installed Air Lift bags in my rear coils and it gives 1,500# extra capacity for under $100.I also got new 3/4t coils whick brought it up to about $200.The truck was being used in my contracting business and had a Reading steel tool cap,ladders/scaffold,and tools loaded at all times.You could ride it with amount of air for desired ride.They definately make a hauler out of a 1/2t without altering the ride when empty,except you could tune-out body roll if desired.
Always wrenching!!
I pulled this trailer with just furniture on it and it did just fine, but i will be putting some sort of air bag. either a seperate bag or the type that goes inside the rear coil springs. oh and it has a 5.3l/4l60e that i will start in a week or so
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
its all about the +6 inches
Here's a pic of my old GMC with a cab in the back... gave it about a 2 inch drop, and also my longhorn towing a boat, but it's a one ton with leafs and built for hauling, not having hauling as an afterthought.
BlahBlahBlah
8 to 10 inch drop just from sitting on the gate? Wow, You must have no shocks and springs out of a bic pen out back.
#7 | |
![]() I wonder if they are monte carol springs or something> |
Here's mine with a helluva load on her. Ford 9n tractor with brushhog, 3-4"x4"'s, 3- bags of sackcrete, deer feeder on the trailer. And misc. items, plus disc in the bed. I had the tractor pulled a bit too far forward in the pic. I moved it back a little bit on the return trip, and got an extra 10mph out of her.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Tot Roddin'
Always love seeing those old trucks still at it!
Sicmaro, that will be one slick truck when complete.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Always wrenching!!
thanks!!!! not much left to do, just wiring.
I don't have coils but here mine boat has about 400 pounds of tongue weight and I load the truck with camping gear and wood. It doesn't even drop down to level.
69 Chevy 4x4 383 Power ![]() |
#13 |
Rear suspension looks factory. I dont know about rusted yellow shocks. I believe PO changed shocks long time ago. What would be better in a long run to change springs or add airbags inside the springs?
#14 | |
Bloo
if im looking at that right you have car springs.. on truck springs, the 3 middle coils almost touch. my 69 had car springs put in it before i bought it, but here is it with about 1200-1600 lbs on it, and unloaded
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#15 |
Its Topless Season!!!!
Here is mine pulling my food vending trailer....I believe it's over 4000lbs fully loaded..Stock height shocks out back...Sorry for the crappy pic( like LHM says "its a crappy camera with a built in phone")
#16 |
Picture one is a buddy from France right before we left to go fishing. I pull my glass bass boat all the time.
The truck also works good to push the dock in the lake. Sorry it ain't coil springs. I think all 4x4s have leaf springs.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#17 |
Junior Member
I am not an expert by any means, but it looks like you have over-load springs(leaf) mounted behind your axle which should give you plenty of load capacity.
An easy way to go is with heavier progressive coil springs to get more weight carrying capacity. Danny |
#18 |
So there I was...
I have leafs in the rear and she sags a little all loaded up for the river:
- Rick 1969 C10 LWB, leafs, 350/700R4, ![]() 2003 Yukon Denali |
#19 | |
Never Ending Projects
Your coils do look much smaller then the ones I just took off my 1/2 ton. The SPID code in the glove box lists them as HD coils. I don't have the overload leafs on my either. Interesting... BTW, you are welcomed to my HD rear coils but you have to come get them in San Diego. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#20 |
Resident of Here
I'm 300lbs, when I sit on our 72 LWB coil spring trucks tailgate, it goes down about 2".
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#21 |
I built this truck just to tow the boat and it don't sag even fully loaded with firewood and all the camping gear. Its got 3/4 ton springs with overloads. Bad thing it will rattle your teeth when its empty.
#22 |
Texas Big Wig
Not much of a load, but here is Sinister with my trailer
![]() And here it is after I got home from Norwood ![]() ![]() |
#23 |
Pat
theirs a sweet pic of one pulling a cat, but i cant find it
#24 |
One of my favorite set ups ever! It was at Columbus Goodguys a few years back...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
