05-19-2008, 04:26 PM | #1 |
How hot is too hot
We are having 100 degree heat in California and I drove to LA yesterday. In heavy stop and go traffic my temp went up to 220 and stayed there. I have electric fans and a high flow water pump with a 195 degree thermostat. Also have a new aluminum radiator. Is 220 too hot for an extended period of time.
69 Chevy 4x4 383 Power |
05-19-2008, 04:38 PM | #2 |
Engine n00b
Re: How hot is too hot
water boils at 212. Antifreeze, 370.
Assuming a 50/50 mix, you should be fine. Personally, I get nervous when my gauge approaches 200, though Last edited by chrislehr; 05-19-2008 at 04:38 PM. |
05-19-2008, 04:43 PM | #3 |
Depends on a lot of factors. Compression ratio, how tight the engine is, and how hard you drive it. One year on holidays we went from LA to Vagas in 120 degree heat, with the motor home flat towing the Blazer. The temp gauge was reading 250-260 degrees all the way. I run synthetic oil the the M/H because it can get very hot. On our trip there were vehicles pulled over about every 1/4 mile cugging coolant all over the place. Even though the temp was a bunch higher than I would like, if I had of stopped, I would have probably been one of those stranded people, in the middle of the desert with my coolant boiling out of the rad. I worried about it the whole way, set the cruise control and let the engine plugg along. This trip had no ill effects on the engine, its been 4 years and 10,000 moles since. Before this experiance I have always had 240 deg. as my shut down temp, and by shut down I don't meen turn the engine off, but do wat it takes to cool it off.
05-19-2008, 04:47 PM | #4 |
220 is nothing.If you have a good anti-freeze mix and a good cap and good oil you should be good to 265.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
05-19-2008, 04:50 PM | #5 |
Me too I spent most of the trip in the slow lanes thinking I might have to pull over but once the traffic started moving it dropped back down to 195
05-19-2008, 05:33 PM | #6 |
I think this is something that not too many people think about. If you rig is getting hot dont turn it off.
72' Custom10 4wd 350: Daily Driver |
05-19-2008, 05:49 PM | #7 |
Oh yeah,that's the worst thing you can do. If the coolant stops circulating it really starts to boil and will totally overwhelm the system.
The right thing to do is pull over and run in neutral a very high idle until it cools down.I've done it one or twice and it works.
05-19-2008, 05:58 PM | #8 |
As long as the coolant level stays full you won't damage the engine. When the coolant level gets low so it's not circulating & not touching the upper parts of the engine is when serious damage results.
05-19-2008, 06:01 PM | #9 | |
20' Daredevil (Ret)
Edit: Another good reason for a sealed system: there is more coolant (and no air), so more heat can be dissipated.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-19-2008 at 06:03 PM. |
05-19-2008, 06:07 PM | #11 | |
Engine n00b
http://en.wikipedia.org/wiki/Antifreeze Its under new developments though, so may not be 100% accurate. Shooting from the hip here. |
05-19-2008, 07:32 PM | #12 |
Junior Member
I have a '92 GMC K-3500 duallie that runs warm when pulling a our 5th wheel travel trailer, by warm I mean 230-250 at times. I have put about 40,000 pulling the trailer and so far have not had any ill affects to the engine.
It has a factory auxiliary fan that is set to come on at 225 degrees. I did have the transmission (4L80E) rebuilt at about 50,000 miles though. I had the guy do a heavy duty rebuild, put in a new torque converter and synthetic fluid. In 1992 they put in some bad shims/spacers and they gave me an extended warranty, but as my luck normally runs the warranty was up before the transmisson went bad. I guess what I am saying is the temperature your truck got up to should not be a problem. Danny |
05-19-2008, 08:01 PM | #13 |
20' Daredevil (Ret)
Just found this image taken from a Prestone jug... dunno if they already accounted for a pressurized system, so the temps *may* be a bit higher.
And this thanks, chrislehr: In the 1980s inventor Jack Evans discovered the advantages of using a waterless coolant. His final formulation is a mixture of ethylene glycol and propylene glycol. This coolant has a high boiling point of 370 °F and is not corrosive, solving many of water's problems including freezing. Most commercial antifreeze formulations include corrosion inhibiting compounds, and a colored dye (commonly a green, red or blue fluorescent) to aid in identification. A 1:1 dilution with water is usually used, resulting in a freezing point of approximately −40 °F (−40 °C). In warmer areas weaker dilutions are used. http://en.wikipedia.org/wiki/Antifreeze_(coolant )
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-19-2008 at 08:05 PM. |
05-19-2008, 08:35 PM | #14 |
couldnt you put like a 160 or 180 degree thermostat wouldnt that help you out
05-19-2008, 08:53 PM | #15 |
All the thermostat does is set the Minimum temperature,and has no bearing on cooling efficiency.
05-19-2008, 09:02 PM | #16 |
I think one problem with higher temps- close to boiling is steam pockets that can form in hot spots. There's this stuff called Water Wetter that's supposed to help with that. I used it on an old Mercedes I owned and it did seem to run a bit cooler. I've never heard of this being a problem on a small block GM that's more or less stock though.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
05-19-2008, 09:03 PM | #17 |
20' Daredevil (Ret)
Yeah, I run a stock (I think) 195 and don't overheat... plus, my heater works in the winter and I don't have to change thermostats with the seasons.
05-19-2008, 09:15 PM | #18 | |
Moderator
05-19-2008, 11:23 PM | #19 | |
As far as the 220.........no sweat. As uncomfortable as it may be, turning the heater on ads another "radiator" and fan into the system. If is is bugging you that bad, turn the heat and fan to "High" |
05-19-2008, 11:31 PM | #20 |
20' Daredevil (Ret)
And that is also 100% correct! Back in '69, I was living in Barstow, CA and drove the '65 Corvette up to Big Bear Lake on a very hot weekend. With a 327/365, it didn't cool too well anyway and it started to overheat. I turned the vents to 'defrost' to deflect as much heat as possible from me (no A/C available with the 365 hp engine), and turned the heat all the way up and the fan on 'high'. The engine was comfortable even if I was not!
05-20-2008, 12:25 AM | #21 |
Then why use one at all?
R.I.P. Scott Kalitta
05-20-2008, 12:47 AM | #22 |
so that your truck can reach peak opertating temps faster for better fuel mileage and heat come winter time
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-20-2008, 12:54 AM | #23 |
Take it out and see how long it takes to get hot air from your heater. The thermostat takes and cuts off the radiator below whatever temp its rated for, so you can get hot air very fast. Once your coolant heats up, it allows it to go to the radiator to cool down.
05-20-2008, 01:01 AM | #24 |
I run water wetter in mine now but when I didn't last year with a 3 speed and it got to 220 going down the highway and as far as turning it off when its hot don't do it you never see a hot dirt car go into the pits and if it hot just shut it down. I run the water wetter now so I'll see what happens this summer.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
05-20-2008, 01:21 AM | #25 |
20' Daredevil (Ret)
Also (though I have never tried this, just something I read somewhere), running with no thermostat can let the coolant circulate too fast -- that is, it isn't in the radiator long enough to cool down, and returns to the engine... continually getting hotter. As a result, you might actually run hotter with no thermostat than with one. True? I dunno, maybe someone here has had it happen...
