05-19-2008, 05:02 PM | #1 |
Currently Blazerless
What does a cracked flexplate sound like?
I have a strange noise that seems to be coming from the torque convertor flexplate area. It only does this after the motor is warmed up good and doesnt do it under power. No funny noises while cranking or starting issues.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-19-2008, 05:11 PM | #2 |
Roadtrip!
Re: What does a cracked flexplate sound like?
I had 2 different ones do this to me and it was most noticable while cranking. I don't recall hearing anything odd after they were running. Take the inspection cover off and look closely around the bolts. I could see where mine were cracked. Good luck, Eric
Oh yeah, check the converter bolts also...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-19-2008, 06:12 PM | #3 |
20' Daredevil (Ret)
When mine cracked, I thought I had lost a rod -- it was a deep, hollow, solid knocking. I was on a duck hunting trip several hours away and had no choice but to drive it home, not knowing if it would blow up at any time...
05-19-2008, 07:20 PM | #4 |
This is more like a squeeking sound, kinda like a belt or pulley would make but it comes from the tranny area..and only once it has warmed up good. I get no noise at all at speed or under a load.
05-19-2008, 07:24 PM | #5 |
I have a radical idea!
That's been my experience with a cracked flexplate as well. I have had the pump of the TH350 make some funky squeaking noises before, and I've heard a bad cam bearing squeak also.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
05-19-2008, 09:16 PM | #6 |
05-20-2008, 04:13 AM | #7 |
What would cause the pump to squeek? and is there a fix for it besides tearing into the tranny?
05-20-2008, 06:00 AM | #8 |
I had the same noise with my 94. I was getting ready to pull things down
when the noise quit. It has not started back. It did not effect the driving in any way. It has a new replacement engine but the trans has over 270,000 miles. It will sure be interesting to me if you find it. If mine comes back and I find it, I will let you know. EdB |
05-20-2008, 06:45 AM | #9 |
When I had one break it made the knocking sounds along with some squeaking noises. it was on a 77 k30 400/400 (maybe the externally balanced engine caused some of the noise since the flywheel didn't balance anymore)
05-20-2008, 06:50 AM | #10 |
Well, Whoop-dee-do!
So it will only do it hot, just in park? Will it do it in neutral? Maybe put the T-case in neutral and put in drive. If the noise goes away, I'd suspect something in the transmission, or possibly the sprag inside the converter. It's been a LONG time ago, but I seem to remember a converter making a mild squeeling noise.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
