Old 05-19-2008, 07:14 PM   #1
slammed70gmc
Axle shaft
Are the axle shafts from a 70 and a 77 the same spline and lenght. They are both 12 bolts, I'm just trying to get a 5 lug rear. Also can I take the front spindels from a later truck and use them. I have a 77 parts truck and the drums just arent cutting it.
THANKS!
1970 GMC 4/6 drop
built 350 with double humps, autometer phantom gauges. WORK IN PROGRESS.
slammed70gmc is offline   Reply With Quote
Old 05-19-2008, 08:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Axle shaft
you have a 75% chance of it being a direct swap.
Pull one out of each and see if they are the same length.
70 was a chainge over year. Some were short (early) some were wide (obviously, later ones).
Old 05-20-2008, 04:54 AM   #3
slammed70gmc
Re: Axle shaft
What about the front?
THANKS!
1970 GMC 4/6 drop
Old 05-20-2008, 04:59 AM   #4
ed2552
ed2552's Avatar
Re: Axle shaft
You will need the newer ball joints, from what i can remember
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 05-20-2008, 05:52 AM   #5
Longhorn Man
Re: Axle shaft
You can remove the whole front crossmember and swap it in with minimal fuss.
Old 05-20-2008, 01:58 PM   #6
70GMCer
70GMCer's Avatar
Re: Axle shaft
and the outer tie rod ends. Just finished doing mine.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
