user title? why?
Shim Shim SHIMMAAAA
Now, when i started my frame-off on my 69 LWB I labelled all important parts and stuck them in bags in an organized fashion..... some how between the move from calgary to cranbrook, the movers lost this box. In this box was the shims for my upper control arms and the pictures so i would remember where to put them again.
Does ayone happen to know what shims to use and where on the front a arm assembly.. or have any pics, so that I can get this thing together... it's the only thing holding me back right now!! Thanks, Cory
-1978 C20 LWB 350 4spd sm465 -1969 C10 LWB Fleetside: 283ci SBC w/ lots of performance goodies ![]() 6-speed overdrive manual tranny, Mcloed Clutch. 12-bolt posi 3.73 gears Belltech sport suspension 1" drop front 2" drop rear. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Re: Shim Shim SHIMMAAAA
Here's a pic. Look closely at the control arm and you can see the shims.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
user title? why?
so.... is there any specific differences to the shims that go on the front bolt as apposed to the back? or is it 3 on each bolt?
Gettin By on Gettin By
I would think the number of shims would be related to what you need for a good alignment.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
I am a Referee of life.
Shims are for alignment.Once everything is together you will need alignment anyway.Just make that the first stop since it will cause premature tire wear.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
And cause the truck to drive funny
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
its all about the +6 inches
if you have lowering springs, you'll need more shims.
You can get a stack of them at the junk yard, or probably at an alignment shop, get it close (eyeball it to where the tire sits verticle) and limp it to the alignment shop for a correct job. As viewed from the front; I-----I is right; /-----\ Would need a butt load of shims; \-----/ Would be way over shimmed. |
user title? why?
Awesome, thanks guys. Really appreciate the help, luckily the alignment shop is only 2 and a half blocks away so i don't need to worry too much. Will definately have to take a trip to the junk yard when i get back from picking up my 78 on monday. Once again thanks alot!
