Old 05-19-2008, 09:24 PM   #1
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Anyone have a fix for this?? maybe some pics??
my doors have 'seperated' some. Kind of bowed out in the middle. Its throwing my window rubber off alot. I can get a clamp and through the vent window and pull it back together, i guess i'll have to weld some sort of brace in the door.
Anyone run across this, or run across a fix??
I guess the 72 doors had the little dimple on the inside with a screw that went to the outer skin that helped this. Thats the 2nd pic.
Maybe anone have a pic of what the side of the 72 doors look like??
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-19-2008, 10:46 PM   #2
jayharrell
jayharrell's Avatar
Re: Anyone have a fix for this?? maybe some pics??
wow, i must be the only one, guess i need to scrap the whole truck and start over. LOL
00 S10 2.2 Vin5
Old 05-19-2008, 10:50 PM   #3
uncle
Take the vent window out and weld it back.
uncle is offline   Reply With Quote
Old 05-19-2008, 11:00 PM   #4
LONGHAIR
You are certainly not the only one,that's why they "fixed" it....in '72.
Some real genius there huh, a "one year" fix, then major change in '73.
Welding something in there is probably the best way to go.
LONGHAIR is offline   Reply With Quote
Old 05-20-2008, 03:25 AM   #5
beautimus
beautimus's Avatar
Yup, it's like uncle stated above. if you pull the window and take the vent window loose and rotate the whole vent window assembly 90 degrees,
you can look down inside the door and see the two tabs from the inside and outside halves of the door. they are about an inch long. they are spot welded together. sometimes the spot weld breaks, and sometimes the tab breaks. oh and since its about an inch or more inside the door its real fun trying to weld it and not weld on the skin of the door. best of luck!!!
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 05-20-2008, 03:56 AM   #6
jayharrell
jayharrell's Avatar
OK. i never saw anything that mounted to anything in there on my 69.
I'll crack it back open tomorow.
Thanks guys
00 S10 2.2 Vin5
Old 05-20-2008, 08:42 PM   #7
Green Machine
Green Machine's Avatar
Rubber on chrome bead trim needs to be trimed off at the back edge of the vent frame, also make sure the bead trim is not too long, I always end up cutting them off some as they are usually too long, that may help some.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-20-2008, 09:12 PM   #8
jayharrell
jayharrell's Avatar
Yeah, i trimmed it up last night. It helped alot. But still about a 1/4 inch gap
I havn't figured out exactly what or how i'm going to weld a bracket in there. I'm going to put my sway bar on tonight, hopfully i'll have some time to go ahead and fix the doors.
00 S10 2.2 Vin5
