Old 05-19-2008, 11:00 PM   #1
bfr57
bfr57's Avatar
TBI swap and AC compressor
Looking at a complete TBI motor (w/accy) to swap into my 71 that has factory AC. Anybody swapped in the factory pancake style AC compressor on these TBI motors?
bfr57 is offline   Reply With Quote
Old 05-20-2008, 06:13 AM   #2
clay68c10
clay68c10's Avatar
Re: TBI swap and AC compressor
Any compressor will work if you get the manifold hoses on it. But, the pancake style aren't meant to be ran all the time like your 71 compressor. I'd change the system over to a cycling clutch.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-22-2008, 03:49 AM   #3
Chevy4Life
Chevy4Life's Avatar
What can be done to a factory system to make the pancake compressor work better. How would the pancake work with a Vintage air setup. I'm still undecided on which to use, but I want to stay with the pancake style comp. that the serpentine setup uses.
Thanks,
Jay
Chevy4Life is offline   Reply With Quote
Old 05-22-2008, 04:09 AM   #4
clay68c10
clay68c10's Avatar
To use one with the factory a/c, you could do a POA eliminator to get the cycling clutch feature. As far as Vintage Air, I'd call them and ask.
There's a bracket set out there somewhere that lets you keep your serp setup and run a Sanden compressor, I just don't remember where I saw it. Maybe Old Air in Ft Worth??
13 Tahoe LTZ
Old 05-22-2008, 04:56 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
I 've always wondered if they made a bracket to fit a sanden ( vintage air type ) compressor to the factory serpintine belt drive . That would be a great seup IMO.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-22-2008, 09:12 PM   #6
Chevy4Life
Chevy4Life's Avatar
I think this is the bracket.
http://www.nostalgicairparts.com/air...racket-355.php
Classic Air has an adapter thats mates there lines to the r-4 compressor, but the sanden is probably better right?
