fugedaboutit
![]() Join Date: Mar 2005
Whats the other outlet on my fuel pump for?
Hey guys, I bought a new fuel pump and told the parts guy the motor was out of a 76 monte carlo, not sure if it was or not because the block #s said multiple listings. Its a 400 sb, anyway after I got the new pump on I realized there is 2 outets and 1 inlet.. the old pump only had 1 in/out.
So my Qs are: Whats the other outlet for? I was thinking of using it for a pressure gauge instead of just capping it off, would that work?
Currently truckless ![]() |
Moderator
![]() Join Date: May 2007
Re: Whats the other outlet on my fuel pump for?
I believe the other outlet is for a line going to the charcoal canister (smog control) but don't quote me on that...
its all about the +6 inches
it is a return line. You can either T i into the feed line, so it just circulates it back to the feed, or return it for the correct 67 - 70 style. If you cap it off, it'll build pressure and damage the unit and leak, and if you hook it to a fuel pressure guage, you'll only read 1 or 2 PSI at best. (not acurate reading)
fugedaboutit
Cool thanks. So longhorn if Im reading you correctly I should tee it back in prior to the pump?
Currently truckless ![]() Last edited by redhead69; 05-20-2008 at 06:22 AM. |
yeah
fugedaboutit
Gotcha.. THANK YOU!!
I would just get the correct one. When Autozone sold me one for my '75, they guy said "they are all like that, just cap it off". It didn't last very long, then they tried to not honor the warranty because it wasn't correctly installed because of the cap.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
