Old 05-20-2008, 01:28 AM   #1
Dadsredwagon
Dadsredwagon's Avatar
3/5 drop not level
just installed my ccp drop kit Coil drop 3inch fron 5 inch rear, when i finished the front only lowered 1.5 inches, well the back is lower then the front oh 65 model swb with a 6 cyclinder, Should I cut the front spring s/ half a coil?
Thx,
Todd
Dadsredwagon is offline   Reply With Quote
Old 05-20-2008, 02:56 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 3/5 drop not level
Before you start cutting look at a few things. Are you certain that you got the fronts springs seated correctly? If the bottom is not clocked in the a-arm it can cause them to sit high.
Also you need to allow the springs to settle. it might take a little driving for everything to find home, but it shouldn't require cutting to get there.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-20-2008, 03:56 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
allow the springs to settle a little while befor you cut brand new springs.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-20-2008, 04:51 AM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
If the above doesn't work, I would contact CPP at let them know your problem. Don't cut those new coils. If they are a 3 inch drop coil, you should a 3 inch drop.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-20-2008, 05:37 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
You have to remember that these springs are 3" lower than NEW "stock height" springs. NOT your 30-40 year old original springs. Just measuring your truck and expecting the new drop springs to be 3" lower is unrealistic. That's why the stance photos on ECE's website help people decide how low they want their trucks. Most likely,... your orginal springs were sagging 1.5" already. (due to age). Throw some 2.5" drop spindles on it, and it will be perfect.
Keith
Convert to disc brakes.
Old 05-20-2008, 05:57 AM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
if gas wasn't so expensive I would say through a big block in it, It could lower it around a inch
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-20-2008, 09:43 AM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Good point about measuring he says that the rear is lower than the front. A 3/5 should be level or at least close. How much lower IS the rear??
Old 05-21-2008, 04:30 AM   #8
Dadsredwagon
can I send ya'll some pics? let me know after the pics what ya think, like the big block idea ;-)
Old 05-21-2008, 03:21 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Post them up on the board... that way more people can see them. If you are unsure about how to post pics, check out the FAQ part of the board.
Check out this LINK to the FAQ page.
-Nate
Old 05-22-2008, 04:10 AM   #10
70c10
67-72 Addict!
70c10's Avatar
Did you drive it yet?. Usually the springs will seat (bang) when you hit your first bump and then your good. Another way to seat them is rock the front of the truck up and down while it's parked and you should hear them pop. I drove mine thru a parking lot with speed bumps to make sure they were seated!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-22-2008, 05:40 AM   #11
Dadsredwagon
yes I have driven it, I'll try some of these ideas, Gota learn to do the pics post...
todd
Old 05-23-2008, 11:47 PM   #12
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Email me your pics Todd and I'll post them for you.
Edit: I've seen it and it's quite a bit lower in the rear.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-24-2008, 05:32 PM   #13
C10 the GEM
Smok'em Roast'em Shift'em
C10 the GEM's Avatar
Do you have any pics?
C10 the GEM is offline   Reply With Quote
Old 05-24-2008, 05:50 PM   #14
HuggerCST
HuggerCST's Avatar
The 6 cylinder probably has an effect on the ride height also.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-24-2008, 06:24 PM   #15
jkaylor68gmc
jkaylor68gmc's Avatar
I agree with N2Trux. If it is not seated properly they will make it sit up an inch. I had this happen to me.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 05-26-2008, 11:38 PM   #16
Slammed '87
Slammed '87's Avatar
I am using springs out of a 6 cylinder in my 8 cylinder truck and they give me close to 2" drop so i would bet that the lowering springs you got are for an 8 cylinder hence not dropping enough.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 06-06-2008, 03:47 PM   #17
70~BigBlock~Project
70~BigBlock~Project's Avatar
Thx,
Todd
All the lowering springs I have seen for these pickups are rated for a SBC. If used on a pickup with a BBC in it, the weight will lower it an addition 1.5". I assume the lesser weight of your I6 is what is reducing your drop by 1.5". I would suggest a set of 2" drop spindles...
1970 Custom/10 LWB-Stock and ugly, for now.
2005 Custom Chopper-100ci Rigid.
2004 Dodge Ram...did he say "Dodge"...
70~BigBlock~Project is offline   Reply With Quote
Old 07-03-2008, 09:36 AM   #18
Charlesdur
Charlesdur's Avatar
Just an FYI If you looked to replace your springs with replacements it is the same part number 3/4 ton to 1/2 ton. Anyways... I have the same issue with my ride and now want to cut my front drop coils to get another 1" or 2" lower. Planning on doing it this weekend. I know that the drop spindles are better, but being a 3/4 ton dropped I can't find what I'm looking for. Either way I will post some pics.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Charlesdur is offline   Reply With Quote
Old 07-03-2008, 03:36 PM   #19
GMCPaul
Charlesdur the 71-87 3/4 ton spindles are the same so you can use 73-87 3/4ton drop spindles to lower your 71-72 3/4 ton.
For those that do not want off the shelf drop springs like the other vendors sell that are all based on SWB small block V-8s are drop springs are custom made to the truck they will be installed in, we provide our manufacturer with the following info
Year, motor size, transmission in truck, length of wheelbase, bed style, and if trucks A/C or Non-A/C they then determine the weight of truck based on this info and then wind & temper the springs based on these specs. That way the guy with a 6 cyl. SWB fleetside Non-A/C manual transmission isn't getting the same spring rate as the guy with a big block, automatic transmission, LWB stepside, with A/C as there is a substational difference in weight. So everyones ride is optimized instead of everyone getting the same spring rate. It does take 7-10 days from time of order to receive them as they are made at right after you order but its worth it in our opinion.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-05-2008, 10:58 PM   #20
Charlesdur
Charlesdur's Avatar
So I cut one coil off of my 2" drop springs and it lowered it two inches... the problem then was that it was bottoming out the arm bumper "don't know the real name" took the angle grinder to it and removed the steel tower.. it rides pretty smooth and handles well still.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Old 07-06-2008, 01:13 AM   #21
chevy_mike
Never Ending Projects
chevy_mike's Avatar
That metal part on the A arm was a combo bump stop and steering stop. You might want to be careful not having any bump stops. I learned on my last '68, which did not have these stops, that I went through a dip a little fast and distroyed my new upper ball joint. With any proper stops, nothing keeps the ball joints from rotating too far.
Just an FYI that I learned the hard way.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-06-2008, 06:43 PM   #22
Charlesdur
Charlesdur's Avatar
this is great info and I agree... I actually only removed the top part of it that was higher then the area that holds the actual bumper stop. so I still have the part in and the bumper mounted.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
