i love summertime
front clip removal...help
i plan on removing the front clip of the 67 this weekend, what all needs to be done? where are all the bolts located? thanks
Derek ![]()
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
![]() Join Date: Feb 2001
Lets see!
two bolts rear of fender top and bottom. One inside of the fender well. two in the front. the front wiring harness will unbolt from the fuss block. u may have to take the cowl off, cant remember (CRS).
i love summertime
thanks mudder
ill have some progress pics this weekend, cant wait to show ya guys a whole lot of nothin, hehe ![]()
its all about the +6 inches
Don't forget to remove (possably) the battery cables, the washe bottle hoses, the bolts under the radiater...and the rad hoses and tranny lines (if equipped).
i love summertime
longhornmail
thanks for the tips, keep em comin
You will have to pull the cowl to get to the top fender bolts. The hardest part for me is getting the wipers off. I'm starting this as well this evening on my 72. Need to replace the heater core and pulling the clip is easier than dropping the inner fender. I'm kind of upset about having to do this again, I installed a new core in January when I put the crate motor in.
If you plan on taking the inner fenders off with it, there is 1 big bolt near the back on the inner side. If you are leaving them on, there are screws to remove on the outside where the innner and outer meet up. The cowl should be removed before doing this job, and the wipers just pop off with 2 screwdrivers.
Good luck and keep us posted
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Post Whore
![]() Join Date: Feb 2000
"Wipers just pop of with two screwdrivers" Come pop mine off for me then - I fiddled with the wipers for 20 minutes last night and couldn't get them to come off :-(
About the bolt on the lower part of the fender just in front of the doors, the metal around that bolt on both fenders was broken off of the inside of the fender. Is that common?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Lift the wiper arm all the way up, look near the base and you will find a lever attached with a rivet. Slide this lever out, this supports the wiper arm and allows you to just wiggle the arm off the shaft.
The other style wiper arms have a hole drilled through the base, lift the arm, slide a drill bit through the base. This supports the arm and again, just wiggle the arm off the shaft. |
Man! talk about timing! I'm planning on trying this over the next couple of days too!
When you guys say front clip, does that mean that i can take pretty much the whole front sheetmetal off all at once? Greg
No such thing as a stupid question, right? |
Post Whore
Yep. It all comes off as one piece. Pretty darn handy for the amount of work your getting ready to do.
Piston, I messed with the little clip that your talking about and still couldn't get it to work loose. Have to work on it some more tonight.
the pot metal and steel they used causes corrosion that makes them tough to move at first.. PB blaster works great for that. It will climb up into the arm assembly and usually makes it so the arms slide right off. If that doesnt work, I've had to make a fork to attach to my slide hammer and "persuade" them off that way LOL.
#13 |
Re: Why guns must be outlawed and confiscated
I think I beat the system...pssting in a closed thread hopefully I won't get :b1: is posting in a closed thread against the :rulz:
![]() Shane Edit: 1 more try
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 Last edited by Chevrolet4x4s; 03-22-2006 at 07:31 PM. |
#14 |
Lets play beat the system
![]() ![]() Edit: I shall have to devise another way to do it Att. Mods I am not a hacker... just bored
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 Last edited by Chevrolet4x4s; 03-22-2006 at 07:35 PM. |
#15 |
Re: front clip removal...help
How did posting in a locked up thread about guns, end up on a 4 YEAR OLD THREAD???
#16 |
Questionable
wtf?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#17 |
I wonder if he ever got the clip off?
#18 | |
Where's my beer?
Paul How do you make the invisible, visible?.........You take it away. |
#19 |
![]() Join Date: Feb 2004
I was also going WTF?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#20 |
Just got back on here going through my old posts rotfl I pulled up a reply page and put in the thread number of the other thread but it didnt work so I ended up looking like a tard
![]() Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
#21 |
Insert Title Here
4 years later........... so how the hell do i get my wipers back on now
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#22 |
Ya still got the wiper studs there?
Shane
#23 |
push really really hard
#24 |
I feel like a retard on this old thread from 2002. Reading back I saw "Dubie".
Where is Dubie now? Wasn't there a whole family of Dubies? Mr. Mrs. and Jr.? Project finished? Burned out? or just quiet. He always had something good to say. I miss that.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#25 |
Dubie's Last Activity: 01-19-2006 03:01 PM
