05-20-2008, 08:24 PM | #1 |
Need some help with 1 ton brakes.
A friends 72 one ton needs some front brakes. I'm having a hard time figuring out what the correct parts are for it. It has a dual rear wheels and 1 pice front rotors. She needs new calipers, rotors, and pads. There is some confusion about which brakes will and won't work. I was even told that hers were '71 specific brakes, even though it is a '72 one ton. i don't believe there was such a thing as 71 specific front brakes. Am i wrong? what were the brake options/ codes for one tons? Does anyone have any good part numbers or insight? Thanks ahead of time!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 05-20-2008 at 08:25 PM. |
05-21-2008, 12:30 AM | #2 |
Re: Need some help with 1 ton brakes.
I am not a lot of help here, but can you match the parts (take her's in and match to the parts place) it'll only work if they have the parts on hand. I haven't heard of 71 specific rotors, but I am not a one ton man.
05-21-2008, 12:34 AM | #3 |
Thanks Mike,
The problem is no one has these parts in stock, so we have to wait for a day to ship. We already had one set sent that didn't work, waiting for another set tomorrow. this is exactly why I didn't want to deal with those front brakes SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-21-2008, 01:23 AM | #4 |
That is strange. I looked in an old Napa catalog & it shows very little for the 72 & nothing for the 71. They must be all by themselves.
05-23-2008, 01:24 AM | #5 |
Okay guys, I need to bring this to the top again. now we are in desperate times and I need some ideas. The rotors received today don't match either. They are supposedly for a '72 also. What I'm being told is that '71 is the only year for this particular brake rotor and no one sells them. Any ideas guys? Does anyone have a'71 one ton frame that has good rotors up front? THis is getting ridiculous!! I need some expert knowledge here guys....cough it up!! Thanks in advance!!
Shawn
05-23-2008, 04:09 AM | #6 |
I'm warning you guys!! this will keep being brought to the top until I get an answer. HELP.
05-23-2008, 06:14 AM | #7 |
I have a radical idea!
What doesn't match up?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
