05-20-2008, 10:00 PM | #1 |
Another HELP question this time Urgent
I just rebuilt my Rochester 2gc and put it back on the engine. It ran great for about 5 minutes and then I started hearing a loud knocking sound coming from somewhere in my engine but I can't tell where. Next thing I notice is puddles of what looks like blackened coolant from my exhaust pipes about 4 feet long and sprayed on my tires (I have turndowns just after the cab angles out slightly towards the side of the truck). What happened? I plugged the intake manifold when the carb was off so I don't think anything got in it, and I noticed that my coolant is pretty much gone after this happened (it was full prior). My water pump is new so what could be the problem?
05-20-2008, 10:06 PM | #2 |
1962 C-10
Re: Another HELP question this time Urgent
Sounds to me like something fell into the intake...like a nut or bolt and got sucked in...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
05-20-2008, 10:29 PM | #3 |
Did you check the oil? If you have coolant in the oil I'd say head gasket.
Good luck, Tim |
05-20-2008, 10:30 PM | #4 |
Yes I had that happen once. Cracked a cylinder and dumped all the coolant in teh chamber. No smoke only because the nut beat the crapola out of the spark plug and it wasn't firing. Sounds like you need to pull the head
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-20-2008, 11:35 PM | #5 |
I have a built 350 with 0 miles sitting in my buddies garage all plugged and wrapped just waiting to go into my truck and I think it might be about time. I just couldn't "fix what ain't broke" but I think this might be a push in the right direction.
05-21-2008, 02:35 AM | #6 |
Well don't forget to open up the enigine and see what happened..
05-21-2008, 03:07 AM | #7 |
65 - Chevy C10
i also had a nut in my 283 when I got it! the piston was pretty jacked! I think I still have it saved for memories.
05-21-2008, 04:13 AM | #8 |
Council of the Elders
I would look first for missing butterfly screw in carb.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
05-21-2008, 05:00 AM | #9 |
05-21-2008, 05:13 AM | #10 |
Will do when I yank it
05-21-2008, 05:22 AM | #11 |
Please, no pictures of that. This isn't that kind of board.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-21-2008, 06:15 AM | #12 |
05-21-2008, 07:58 AM | #13 |
I didn't say "wank it" you sicko
