Old 05-21-2008, 02:10 AM   #1
chevymotocross
chevymotocross's Avatar
Cam for 305 TBI
I have a 1987 chevy r10. I need to replace the condenser, and while I'm at it, the radiator is weak so I'm installing a new radiator. The truck smokes on startup so I am also going to be installing new valve seals. Since I have to remove the radiator and condenser, and will be installing new valve seals, I was juggling around with the idea of adding a mild cam. I have read that the TBI computer does not respond well to radical cams. I'm looking for something that give a nice mild idle lope, and good low end performance. Is there a cam anyone can recommend? The truck is a 2wd, 700r4, dual exhaust, and has some highway gears (assuming 3.08 or possibly higher like a 2.73).
chevymotocross is offline   Reply With Quote
Old 05-21-2008, 02:55 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Cam for 305 TBI
Call this company http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
You can add a cam with the proper eprom.
gchemist is offline   Reply With Quote
Old 05-21-2008, 06:09 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Cam for 305 TBI
Talk to www.tbichips.com Whatever you decide, you are going to have to have a chip to take advantage of the cam unless you go very mild.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
