Old 11-05-2002, 08:21 PM   #1
My Boy's Toy
Engine Rebuild Kits ?
time to rebuild my 327 , who has good kit's & any sugestions on what to look for or stay away from . Thanks
My Boy's Toy is offline   Reply With Quote
Old 11-05-2002, 09:33 PM   #2
MikeB
MikeB's Avatar
I would buy brand name U.S.-made parts like TRW, Sealed Power, Federal Mogul, Mellings, and Fel-Pro. Summit Racing sells good rebuild kits with name brand parts. You might also check with Scoggin Dickey at SDPC2000.com. I've seen inexpensive kits by EngineTech, but I fear the parts may be made in Taiwan or China.
If you're a beginner, get a good book like "How to Rebuild Your Small Block Chevy" by David Vizard. It's $12.00 at Amazon.com.
Remember the parts that wear the most in a 327 are valve guides and cam lobes, so DO buy a new cam and lifters and have a machine shop look at your heads. Do not have the valve guides reamed -- have them replaced or buy rebuilt heads.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-05-2002, 09:34 PM   #3
Mike C
Mike C's Avatar
www.northernautoparts.com check out their highperf rebuld kit for a 350, they should be able to substitute parts for your 327 for whatever the difference in price.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-05-2002, 09:49 PM   #4
My Boy's Toy
I'm rebuilding a 70,000 mile 327 -275HP , I'm going to replace the cam & lifters for sure . going to mike the valves & gides tomarrow night , think I should put in hardened valve seats ? I'm going to keep it stock
Old 11-05-2002, 09:56 PM   #5
bigjimzlll
bigjimzlll's Avatar
hardend exhaust seats are a good idea
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-06-2002, 03:33 PM   #6
Mike C
Mike C's Avatar
Unless you pull a heavy load quite often or you have had several valve jobs or valve recession on the head, I would not bother with the hardened seats. I have over 100k miles on my 186s since the last valve job. If you do big valves or you have had a valve job done once or twice before, I would do the hardened seats.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-06-2002, 05:42 PM   #7
gashog
Active Member
gashog's Avatar
Gotta put a good word in for summit racing. Great selection, service and price.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 11-06-2002, 05:51 PM   #8
COBALT
COBALT's Avatar
I second that on Summit. I buy from them all the time.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
