Old 05-21-2008, 05:33 AM   #1
72 Cheyenne402
72 Cheyenne402's Avatar
RE7 rear bag ride height
I am almost ready to buy my rear bags. I am looking at the RE7's and I have two questions
1. right now I have 4" ECE drop springs in the rear & 2.5 drop spindles in the front I do not plan to bag the front. My overall wheel Dia. in the fron is 28" and rear 30". What is the normal ride height of rear bags?
2. What does it take to install these bags? Do I need any additional brackets for the air bags?
Thank you for any advice or help
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 05-21-2008, 06:14 AM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: RE7 rear bag ride height
not sure on heights, i just took my srpings out and bolted the bags in its a really simple process on the trailing arms.
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 05-21-2008, 06:24 AM   #3
72 Cheyenne402
I didn't want the rear to sit lower than the front at ride height
Old 05-21-2008, 04:24 PM   #4
TravRMK
TravRMK's Avatar
Just air them up untill you like the ride height.
TravRMK is offline   Reply With Quote
Old 05-21-2008, 07:47 PM   #5
jimmydean
jimmydean's Avatar
I used a small cup in the rear to keep from hitting the frame because I didn't use a c-notch. I also didn't have to drill a huge hole in the spring plate because I was able to route the hose out of the side of the cup.
Ride height on an RE7 is about 4" for the best ride quality. With the 2.5" cup I had, it was about the same as a 7" spring. Not sure how tall a drop spring is, but they say you should notch the frame at 4" of drop. I never hit the frame and at full dump, my frame was just resting on the factory bump stops.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-22-2008, 07:50 AM   #6
edflores
i think 6-7" is recommended ride hieght for those. 2.8 is fully compressed and 10" is fully extended if i remember correctly. i ride around with 40 psi in the rear of my mini and it feels a little too stiff.
edflores is offline   Reply With Quote
