05-21-2008, 07:29 AM | #1 |
TILT COLUMN GURU
Tach dash rebuilt like new
This has been completly reconditioned. Includes new bezel, tachometer,printed circuit and bulbs. Lens is original but has been polished to better then new conditioned. all gauges have been tested. Needles have been painted. Odometer has been reset to zero.
I stand behind all my work. $450.00 shipping incl. anywhere in the U.S. |
05-21-2008, 02:19 PM | #2 |
1967 C-10 SWB LS-6 T-56
Re: Tach dash rebuilt like new
Just a question, what is the easiest way to reset the od to 0?
Thanks |
05-23-2008, 07:35 AM | #3 |
TILT COLUMN GURU
Remove odometer wheel, remove plastic retainer,then starting from the left set each number to nine and turn wheel one more time to 000000
05-24-2008, 06:56 AM | #4 |
TILT COLUMN GURU
Complete wire harness for tach Incl.
05-24-2008, 04:21 PM | #5 |
Just a question how do you polish the lens? What do you use? Would appreciate some advise.
05-24-2008, 07:56 PM | #6 |
Meguiars and Mothers both make a plastic polish and the speed ball works pretty good (just don't polish the side of the lens with the numbers)
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
05-24-2008, 10:58 PM | #7 |
Thanks for the advise
06-03-2008, 01:29 AM | #8 | |
TILT COLUMN GURU
06-03-2008, 11:43 AM | #9 |
Would this fit in place of any stock dash. Mine is set up where the blinkers and generator light are in where the tach sits. It has an aftermarket tach set up on the column already, I believe its a sun tach, would the wiring for that work for the tach in the restored dash. Im thinking everything should just connect right up, or is it not that easy ? Would love to have that and get rid of all the other after market gauges. Thanks
Shane |
06-03-2008, 08:29 PM | #10 | |
TILT COLUMN GURU
06-03-2008, 08:51 PM | #11 | |
Fix It Till It's Broke
Kev...do you sell the tach by it's self with wiring harness? I have a really solid dash in my truck just need the factory tach itself. If so how much with shipping? PM me if you would.
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
06-03-2008, 09:38 PM | #12 |
TILT COLUMN GURU
You would also need the inner tins, the printed circuit and also the lens. You would be better off buying the one I haveand selling yours.
06-03-2008, 09:51 PM | #13 |
Thanks I'll look into it. Not quite sure how much I could get out of mine.
06-07-2008, 01:38 AM | #14 |
Junior Member
Kev, How much to pickup from you? vs shipping? I am in SF.. Thanks
07-12-2008, 07:00 PM | #15 |
TILT COLUMN GURU
ttt
07-14-2008, 10:33 AM | #16 |
Super nice work. At the end of the summer I would like you to rework my dash. How long would you need to have it?
Thanks, Dan |
07-14-2008, 10:58 PM | #17 |
TILT COLUMN GURU
