05-21-2008, 08:07 AM | #1 |
Rear Differential Swap and Gearing Question??
I have a 67 GMC that Rod helped me decode the VIN as a V6 and standard trans. It currently has a 350 with a 350 Turbo.
The gearing is wrong for the trans and am debating on getting it regeared or swap the rearend from something comparable. As far as I can tell it's the stock 12 bolt with leaf springs. Any comments or suggestions welcome. Last edited by jsburton69; 05-21-2008 at 08:15 AM. |
05-21-2008, 09:06 AM | #2 |
Re: Rear Differential Swap and Gearing Question??
I could give you a shorter version, but this website should explain things pretty well; how to determine your gear ratio.
http://www.jedi.com/obiwan/jeep/misc/gearratio.html
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e Last edited by chevy72blu; 05-21-2008 at 09:06 AM. |
05-21-2008, 10:31 PM | #3 |
its all about the +6 inches
you gotta know what you heve before you know where you need to go.
A lot of people will say a 3.73 is fine (which you probably have) however, if you have a 3.07 in there, and it's still too low for you, then you may lose a lot of money to get no where. |
05-23-2008, 03:58 AM | #4 |
Hard to tell from photo, but the standard axle on 67 GMC should be a dana 44. The came in all sorts of ratios from 3.07 to 3.54 to 4.11.
