05-21-2008, 07:28 PM | #1 |
New Member
5 lug axles
can anyone tell where to look for replacement axles? to change to 5 lug. i had found a site before but cant find it now.
thanks in advance.
1968 SWB Project. Soon to Start Build Thread |
05-21-2008, 08:03 PM | #2 |
Re: 5 lug axles
It would probably be cheaper to take your old axles down to a machine shop and have them redrill them for you.. ECE sells them.. http://www.earlyclassic.com/catalog.aspx $319...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 05-21-2008 at 08:04 PM. |
05-21-2008, 08:13 PM | #3 |
Re: 5 lug axles
My father bought an entire 75' year model 5 lug axle assembly from the wrecking yard and replaced his 6 lug axles with the later model ones. They were an around 1" long so they will need to shortened but the axles fit with now problem. Hope that helps.
05-21-2008, 08:29 PM | #4 |
Re: 5 lug axles
I got a whole rear end out of a 71-72 and just bolted it into my 65. The whole rear end..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-21-2008, 09:35 PM | #5 |
65 - Chevy C10
Re: 5 lug axles
the 71-72 is a little wider right, but you can just get rims with different backspacing.
I was told that their is really no reason for switching to 5 lug unless you REALLY want to get some wheels that only come in 5 lug. Otherwise, most truck rims offered today are made for 6 lug as most newer trucks/suvs are 6 lug. If anyone else has different reasons please let me know. It seems like a popular swap, just not sure why. |
05-21-2008, 09:49 PM | #6 |
New Member
Re: 5 lug axles
i am wanting to swap, because i am putting on the 73-87 front disk brake setup and it is 5 lug.
thanks for your help, fellas
05-22-2008, 12:53 AM | #7 |
Re: 5 lug axles
Just get 6 lug rotors... They fit on stock chevy spindles. Ask the vendor of course.
05-22-2008, 12:56 AM | #8 |
Re: 5 lug axles
Edited by mod. For sale must be in the classifieds.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by Fred T; 05-22-2008 at 09:24 AM. |
05-22-2008, 06:10 AM | #9 | |
Council of the Elders
Re: 5 lug axles
The 71-87 five bolt swap is so popular because: 1. it is easy and inexpensive with common GM salvage yard parts, and 2. it used to be the only way to do it. Now the manufacturers are offering the six bolt option with original smaller balljoints and tie rods... good in some ways but makes it more confusing too. I think there is now also a five bolt option that uses the old smaller ball joints and tie rods.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-22-2008 at 06:21 AM. Reason: give more info |
05-22-2008, 07:11 PM | #10 |
Re: 5 lug axles
Yeah i wanna upgrade my self. i saw some wheels on www.newstalgiawheel.com
I think purchasing the 4x6 drop(5lugconversion) kit plus the 5lug axle conversion & the 20's in which i'm after is a bit much so i'll go these 17's n chill for awhile until i decide how i want my truck to ULTIMATELY look!
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
05-22-2008, 07:41 PM | #11 |
65 - Chevy C10
Re: 5 lug axles
So pretty much the reason for the lug change would be to get rims that only come in 5 lug. I was just hoping someone had a reason or explanation if there is some other benefit, but there seems to be no other real benefit. Which is fine to me if you REALLY need the rims.
05-22-2008, 07:41 PM | #12 |
SIR
Re: 5 lug axles
...I would go with a 67-72 rear end ,if you have a fleetside bed just trim off 1-1/2" off the lip of the wheel well ...and I like your choise of wheels,close to what I put on ours.....
66long low fleet http://community.webshots.com/user/LVNR66 |
05-22-2008, 09:14 PM | #13 |
65 - Chevy C10
Re: 5 lug axles
or order the wheels with different backspacing
05-22-2008, 11:43 PM | #14 | |
Re: 5 lug axles
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
05-22-2008, 11:46 PM | #15 |
Re: 5 lug axles
I agree- those are fine looking wheels! Reminder: only 71-72 gets you to five-bolts.
05-23-2008, 12:17 AM | #16 |
Ol' Blue Viking
Re: 5 lug axles
I got axles drilled 5 lug for under $100.
Why all the hooplah, I'd pay $100 not to have to change rearends. I certainly wouldn't put an wider axle in my truck.
Driving Paw-paws truck into the Sunset! |
05-23-2008, 12:42 AM | #17 |
1962 C-10
Re: 5 lug axles
I have a '72 rearend on my truck. I never knew it was wider than the stock one. With the wheels I've used, it's never been an issue...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
05-23-2008, 12:50 AM | #18 |
Re: 5 lug axles
Believe me, with some wheel and fender combinations, that 1 1/2 inches matters. I took the 71-2 axle out of my truck and reinstalled the original and had the axles redrilled... though some shops don't want to do that kind of work anymore. It is true that in some cases you can get custom offset wheels to fix the problem created by fixing the previous problem.
05-23-2008, 01:26 AM | #19 |
Re: 5 lug axles
05-23-2008, 03:57 AM | #20 |
65 - Chevy C10
Re: 5 lug axles
I also heard that redrilling can be somewhat unsafe. The pattern conflicts with one of the existing holes. Is this true?
05-23-2008, 02:44 PM | #21 |
Re: 5 lug axles
IMO it is not a significant issue. Shop that did my work ten years ago didn't say anything about that. They did comment on how hard he steel was though. FYI you also must turn the register or hub down to a smaller size when this machining is done.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-23-2008 at 02:45 PM. |
05-23-2008, 03:00 PM | #22 |
Hollister, CA.
Re: 5 lug axles
I heard once, somewhere, that 71-72 axle shafts will slide into my housing ('63)...evendently, this is not true.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
05-23-2008, 03:11 PM | #23 |
Re: 5 lug axles
They are too long for the bearings to ride in the right places... also the number of splines changed somewhere in the 60s, but I'm not completely sure when... I think the 65-66 have same splines as later models. I notice that axle conversion kits for up through 64(?) also contain new spider gears.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-24-2008 at 04:07 AM. Reason: fix mistake??? |
05-23-2008, 04:25 PM | #24 |
Re: 5 lug axles
if you have a stepside the wider rear end from a 71-72 will cause a small problem with fender clearance. If you have a fleetside it won't be as much as a problem.
They used those stepside beds from 1955 to 1966 as you know. And the 50's trucks were not as wide as the 60's trucks and they never did widen the bed fenders for the 60's trucks. So the 3/4 of an inch on each side for a fleetside bed is not as bad as it is with a stepside bed. The tires on my truck now are 245/60/15" only because I could not go any bigger with the stepside bed. Since I dropped the fleetside bed on I have plenty of room. I can snap some photos if you need a visual..
05-23-2008, 05:22 PM | #25 |
Re: 5 lug axles
I bought a 79 C10 for the front end parts (ps, disc brakes, etc) to use in my 66 C10. Question, can I use the axles out of the 79 and just cut 3/4" off the end and cut a new groove for the c-clip or is the spline different or not long enough to engage the spider gears properly?
