05-21-2008, 10:42 PM | #1 |
master cylinders
I just called CPP to order a new master cylinder for my truck build. I wanted to order the CP31500. Sounds like a good piece, and since it can be used with both rear drums and discs, figured it would be good since I have drums now but will later swap out to rear disc. Problem is, they only make the chrome versions now, and that wouldn't be bad, cept I don't have any chrome on my truck at all. It seems pretty stupid to me to have only one chrome part on the truck. Sooooo, my question is, does anyone know where I can find one of the original CP31500's? Or even the CP31500-P is a polished unit, not too much bling on it. The CP31500-C is just too much chrome for what I'm doing.
65' Chevy C10, Short Step 75' Chevy Big10 1/2, 1 time pull truck, now parts truck 02' GMC 2500HD 8.1L 4X4 |
05-21-2008, 10:54 PM | #2 |
Re: master cylinders
are you running a booster? I used a master from a 70-72 truck, inexpensive and works great. I can get you a part number if you want.
CHEVY ONLY |
05-22-2008, 01:00 AM | #3 |
I got one of these... http://store.summitracing.com/partde...5&autoview=sku $199 for the natural and $239 for the polished.. I wanted something that looks nice. I even forgot I have it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 05-22-2008 at 01:01 AM. |
05-22-2008, 03:47 AM | #4 |
Resistance is Futile
If you dont mind paying for the chrome.......a can of spray paint would fix it up to match whatever you want!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-22-2008, 05:35 AM | #5 |
Thanks for the replies guys. I hate to pay $200 for the chrome only to paint it, but it is an option. I was looking at the CPP one for the flexability of running disks or drums on the rear. The Wilwood one won't do that, I don't think. If it does, I definately be interested. Was hoping someone had a line on them I could get.
05-22-2008, 06:35 AM | #6 | |
Council of the Elders
http://www.performanceonline.com/sto...at=1085&page=1
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
05-22-2008, 07:20 AM | #7 |
Registered.........
Well, another option is to use a master cylinder spec'd for a 19701-1972 C10 - it will work with either drums or discs and a new replacement from your local parts house shouldn't cost more than $50.00. You will need a proportioning valve specific for either the drums or discs though.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
05-22-2008, 05:16 PM | #8 | |
05-23-2008, 04:06 AM | #9 |
You can also just use a late model truck master cylinder. They are cheap. I used a manual proportioning valve and gages so I know the pressure split. I have rear discs so manual settings allow me to get all 4 wheels to lock up together.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
05-23-2008, 04:32 AM | #10 |
Tr65, thats a cool set-up. I was curious what accesory set-up you're running. Driver side serp alternator?
Not trying to jack the thread...........
05-23-2008, 05:35 AM | #11 |
cheif rocka may chime in he has used an 60 somethin' drum/drum master?
td |
05-23-2008, 05:39 AM | #12 |
Protrash,
It is an aluminum serpentine belt system I got on evilbay for $100 (3 machined billet pulleys). Worked out nice. (Measured the belt length with a string, looked it up in Gates catalog) Like this and there are several similar ones http://cgi.ebay.com/ebaymotors/HOT-S...spagenameZWDVW Darn, they are cheaper now. TR
05-23-2008, 04:29 PM | #13 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 05-23-2008 at 04:35 PM. |
