2wd to 4wd conversion SWB Truck using Blazer Frame
Im new to this site and i have been browsing a little here and there. Im trying to figure out if its Easier to do this conversion in these two options. Keep in mind I have both vehicles sitting next to each other. Every peice i should need(besides the fabricating) is there.
A: Take the suspension, brackets, crossmembers out of the blazer and put them under the 2wd frame. B: Take the SWB body off the SWB frame and put it on the Blazer frame. Now i know the blazers are shorter so that poses the biggest problem. The 2nd problem i know exists is the flare on the 2wd frame that is non existant on the 4wd frame. This so far is the only problem i THINK is lying in front of my suspension swap. Thats why I am more fond of the whole suspension conversion, it seems the easiest route. But a couple of people I have spoken with say that sectioning a frame isnt that difficult. That i should take it to a Professional chassis/welding shop and have them extend it the difference of the 2 frames. Keep in mind that this is not the route i want to take, so try not to give me a hard time lol. ANY info is very helpful and much appreciated. ![]() |
![]() Join Date: May 2006
Re: 2wd to 4wd conversion SWB Truck using Blazer Frame
First off welcome to the board, could you mount the front 4wd to the truck if you got rid of the 2wd crossmember. I always thought the trailing arms were the best for rear suspension, but that is JMHO
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#3 | |
SKINNY TIRES RULE!
First, a blazer is worth more than a short wide. I realize that 4wd short wides are in short supply, so if the blazer is rusted and the truck is solid, it's probably a good swap. I would think it would be easier to put the suspension on the PU frame. If you use the blazer frame, you'll need to fab body/bed mounts in addition to making it longer.
Here's an article on converting a 4wd Blazer to 2wd. I realize it's the opposite direction that you are going, but it might give you some ideas of what all is involved and what lines up, etc. http://www.sporttruck.com/techarticl...ion/index.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L Last edited by bouncytruck; 05-22-2008 at 01:27 AM. |
#5 | |
![]() Quote:
Talked to a friend at Hibbards Iron works today. Quickest and easiest way is to lengthen the blazer frame. It will be as strong if not STRONGER than stock. Which is exactly what i wanted to hear. Edited by Moderator
![]() Join Date: Dec 2007
Edited by Moderator
Designated A-hole!
You both need to subscribe and start a thread on the parts board as necessary.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
