Dropped Spindle Brake Hose Q + Caliper Bolt Length
HI all,
I have an '86 LWB 2WD GMC, and I am in the process of installing a McGaughy's drop kit on it, 2.5" drop Spindles in front, 4" drop hangers in the rear. Anyway, the new rubber brake lines I bought basically interfere with the upper ball joint once installed. What alternatives have you used that work? I hate to bend the steel part of the line for clearance, and I'm not sure it will work. I was thinking braided steel lines...if so, anyone got a part number(s)? thanks! Last edited by mercman1951; 05-22-2008 at 05:33 AM. |
Re: Dropped Spindle Brake Hose Q
I had to bend the brake lines a bit when I put spindles on my dually.
Magnificent bastard
Yup, bend it.
1977 Big Block Burb |
Thanks guys.
New problem...caliper bolts form my NON-HD calipers and spindle are too short. I upgraded as a result of the spindle requirements. Anybody have a part number for the HD ones? I looked on NAPA's website but they don't specify between HD and non-HD rotors/calipers...just trying to head-off a parts counter debacle...looks like I need new ones that are 4-1/2 to 4-3/4 long. thanks again.
there hard as hell to bend though. i just reangled mine they worked just fine so far
#7 | |
Maybe adjusting it in a vice, making a small bend, repositioning it, nudging again, etc, till it clears? Last edited by mercman1951; 05-22-2008 at 05:02 AM. |
I had the same problem. I bent the stock lines but I also bought new braided lines from Summit and the ends are smaller. They will fit much better than the stock lines.
#9 | |
Thanks... P.S. What about your caliper bolts? Did you need longer ones? |
#10 | |
Magnificent bastard
I bent mine on the vehicle... It didn't take much, but yes, do be careful.
