Old 05-22-2008, 03:29 AM   #1
rod murphy
Unhappy Help ! 72 won't accept fuel
I am not able to get fuel into the fuel tank on my 72 . It is a new rear mount poly tank and the filler hole is on the left rear side about 2 inches higher than the clearance light. It is well vented to the atmosphere with two seperate vent hoses and the fill pipe/hose has a smooth transition down to the tank. I can put fuel in with a gas can........but when I try to fill it at the pump gas just spits out and the nozzle keeps snapping off. Anyone have any ideas ????????
rod murphy is offline   Reply With Quote
Old 05-22-2008, 04:00 AM   #2
cablazer
70 4x4 k5 Blazer
cablazer's Avatar
Re: Help ! 72 won't accept fuel
Wow that's crazy, I'm having the exact same problem. I also installed a poly tank with it vented to atmosphere on both sides. I was just searching previous threads, but found nothing specifically regarding this problom. I noticed my fill hose angles back up before dropping in the tank, could this be the problem?
cablazer is offline   Reply With Quote
Old 05-22-2008, 05:23 AM   #3
RED72blazer
urban fourwheelin
RED72blazer's Avatar
you have to pull the nozzle out a bit and hold it while you pump.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 05-22-2008, 06:37 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
That's what I have to do with my stock filler neck/tank too. I also have to monitor it while filling because it will overfill
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-01-2008, 09:09 AM   #5
tsetsaf
I also am having the same problem. I went as far as removing all the filler hoses out to the side of the bed, cutting a square in the bed floor and inserting the gas nozzle directly into the 3.5" of hose attached to the neck.
I think the poly tank has some sort of restriction on the filler. Where did the other two get their tanks? I bought mine from a vendor on eBay.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 06-02-2008, 12:56 AM   #6
Long Roof
Old School, New Style
Long Roof's Avatar
Mine also has the poly tank. I bought it that way. I have to hang the noozle almost all the way out to get it to pump. It is pretty easy to overfill. The filler is in the stock location.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 03-31-2009, 04:37 PM   #7
cablazer
70 4x4 k5 Blazer
cablazer's Avatar
FYI: I just wanted to update you all on my fuel tank problem. I have tried just about everything I could think of to fix the extremely slow fuel filling problem. Including adding more venting and re-routing the fill hose on my poly tank, but nothing worked. I finally bought a used fuel tank neck off an original tank from a member of this site and used fuel hose and hose clamps attached it to the inlet of my poly tank. Now it works perfectly and I can even place the gas pump on the highest setting and let it run. I guess it just needed this part to make the correct angle around the body mount.
Old 03-31-2009, 06:14 PM   #8
Green Monster
Green Monster's Avatar
Any pictures?
Green Monster is offline   Reply With Quote
Old 03-31-2009, 11:22 PM   #9
truckster
truckster's Avatar
I thought it was just me. Mine is the same; I have to listen for the sound of it getting full, even though I replaced all the hoses.
truckster is offline   Reply With Quote
Old 04-03-2009, 12:28 AM   #10
hgs_notes
GEARHEAD
hgs_notes's Avatar
I had this problem using an original tank and found that the vent line from right next to the tank fill inlet was blocked. Once I cleared it, the gas filled just fine. Check your vents!
hgs_notes is offline   Reply With Quote
