05-22-2008, 06:32 AM | #1 |
Heater Delete plate dimensions?
Does anyone have the dimensions for a heater delete plate? I know it is a little bigger than the radio delete plate. I am trying to figure out if one will work for me. tHanks!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-22-2008, 07:28 AM | #2 |
Retired Air Force Veteran
Re: Heater Delete plate dimensions?
Shawn,
Check with Board Vendor-Wes at Classic Heartbeat. PM is Classic Heartbeat. Toll Free at 888-338-2502 or the Website is www.classicheartbeat.com
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
05-22-2008, 08:31 AM | #3 |
Velocity Speed Shop
Hey Shawn, how's it going? I think that this site may be of some help, they have them already made.
http://infantirides.com/products/009.htm
--------------------------------------------------- My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143 My Garage ..... http://www.hubgarage.com/mygarage/OCD69 |
05-22-2008, 01:43 PM | #4 | |
1997 GMC Sierra Ext 1965 Mustang |
05-22-2008, 02:11 PM | #5 |
sorry if I misunderstood. You may have to fab that one. I tried looking for one of those and no luck. I had nothing there. I went to a swap meet and found a really nice heater/non ac controller. My truck doesn't have factory air. Good Luck.
05-22-2008, 04:01 PM | #6 |
Thanks guys! 70 GMCer you are right. I'm looking for the heater delete plate below the radio. If I told you why I wanted it you would probably have me shot, so I won't explain... for now.
Shawn
05-22-2008, 04:03 PM | #7 | |
Shawn
05-22-2008, 07:50 PM | #8 |
Shawn here is my heater delete.
I didn't even know they made one for the heater area. I don't have the exact dimensions, but your opening is about 1/2" wider than a DIN , and the height is the same. Thus why I did this.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-22-2008 at 07:50 PM. |
05-22-2008, 08:47 PM | #9 |
That was my plan, however I wanted to use the delete plate to frame the radio, give it a more finished look. I was going to use an extra radio delete plate I have, but the trim on the radio hits the rolled edge of the delete plate. i wanted to see if the heater delete plate was taller than the radio so I could use that instead. I plan on using the Vintage Air controllers mounted to the radio delete up top in the radio area. I just didn't want to tell anyone I was considering cutting up a Heater and radio delete plate .
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 05-22-2008 at 08:48 PM. |
05-23-2008, 01:05 AM | #10 |
Shawn that is what I am doing. I'll be mounting the controls in the radio delete. I have not decided yet whether I will weld in the gab around the DIN, or make some sort of temp filler.
Here is a thread about same thing. http://67-72chevytrucks.com/vboard/s...d.php?t=267198 Orange sent me his template diagrams which are very useful I thought I was going to do some of it this weekend, but I have another body/welding project now to get done.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-23-2008 at 01:08 AM. |
05-23-2008, 01:52 AM | #11 |
Shawn,
Check out this new vendor, Mekdad. He's got a CNC machine and may be able to Custm Make your delete plate. Good Luck.' http://67-72chevytrucks.com/vboard/s...d.php?t=292821
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 05-23-2008 at 01:54 AM. |
05-23-2008, 08:25 AM | #12 |
Velocity Speed Shop
Not even close, the "clean" garage is no more. Parts are everywhere, including oil, and power steering fluid, and..........and............and.............and........and. HAHA. I finally had a chance to get my hands dirty, the font end is off and the engine is comming out so I can get to the suspension and frame. After the engine is out the bed is next then the cab. I am going to try and sand down as much of the frame as I can (unless you know of an easier way, i.e. cheap) to get to bare metal. I want that real smooth look, not that rusty pitted look. The frame itself will be all silver, and some of the other parts will be black. Take care
