05-22-2008, 08:23 AM | #1 |
Chevy nut
An idea...Will it work??
Anyone ever tried to use a p/s box out of a 73 to 87?? Will it work?? Not work?? Am I crazy?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
05-22-2008, 11:42 AM | #2 |
Re: An idea...Will it work??
The steering boxes will work in our trucks. Somewhere in the 73-87 years the fittings were changed on the box so that will need to be addressed. I believe that if you get one in the 73-81 years it will be a direct swap.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-22-2008, 01:20 PM | #3 |
its all about the +6 inches
AND... you'll benifit from a variable ratio box too.
05-22-2008, 02:40 PM | #4 |
Chevy nut
Since I am gutting the 87...thats what I am going to try and use it.
05-22-2008, 03:21 PM | #5 |
You`ll just need custom hoses because the fittings are different.I guess it depends on which pump you have.I`d imagine with the later pump the lines for an`87 would work...right?
05-22-2008, 03:43 PM | #6 |
use the gear box and pump from the same donor, or you can swap the fitting that screws into the pump to get the correct style fittings. i had a truck that the PO had a custom high pressure hose made, works fine, but if you have a leak in BFE you might have trouble getting a hose made. you could have a spare made and carry it with you
CHEVY ONLY |
05-22-2008, 06:08 PM | #7 |
Are the 73-87 fittings the same as you would find on a late model 5.3/6.0?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-22-2008, 07:37 PM | #8 |
I believe 81 was the year that they went from the flared/SAE thead fittings to the metric/O-ring fittings. Any of the O-ring fitting box should mate up to late model pumps, including the 5.3 etc.
As mentioned which ever way you go, get the pump also from the donor vehicle, and swap the fitting on the back of your pump with the one from the donor vehicle. That way you can use a standard hi-pressure line (donor vehicle). Since I went Late model serpetine setup on my engine, I swapped back to the SAE/Flared line setup to mate to my 72 steering box.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-22-2008 at 07:38 PM. |
05-22-2008, 09:10 PM | #9 |
You can also get adapters and keep your hoses:
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-22-2008, 10:53 PM | #10 |
I recently put a p/s box out of a 1977 scottsdale into my 1970. Bolted right in without any modifications whatsoever.
05-22-2008, 11:55 PM | #11 |
Make sure you use the rag joint that is with the box, shaft size changed sometime in there, and may need to swap pitman arm.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-23-2008, 04:30 AM | #12 |
I have a gearbox off a 89 Suburban on mine. I am using the serpentine belt setup off the suburban also. I had to use the lower half of the Suburban rag joint on the 72 tilt column shaft.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
05-23-2008, 05:25 AM | #13 |
Wish I would of found this discussion a couple months ago when I installed a quick ratio gearbox on my 67.
I don't really care for it... it's great when driving under 50 and for sharp turns but it's too sensitive when going over 60. A variable ratio sounds like the hot ticket. |
05-23-2008, 02:37 PM | #14 |
Chevy nut
I plan on grabbing everything off the 87. There isnt going to be alot left of the 87. Yesterday the motor and trans was out in a hour. Since it all was just put in about 2 months ago...it all was still fresh to put it. My truck is manual and its been a real pain at times to drive it. 20 years ago it wasnt a big thing for me to drive a truck with out P/S...but at 40 it seems to be a major pain! Since I am grabbing the crossmember and whole front suspension...it should make and easy swap.
05-23-2008, 05:33 PM | #15 |
Confirming that 81 is the cut over year for flare to o-ring.
I've also used these with great success: http://www.gottashow.com/ps_hose_kits.php Stainless lines that use copper gaskets to seal, instead of o-ring or flare. Last edited by FormerMember; 05-23-2008 at 05:36 PM. |
05-23-2008, 10:22 PM | #16 |
What is "variable ratio"? I have a box out of a '79 with same ratio as the original box, and I'm pretty happy with it. I think the quick ratio was an option that year -?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
05-27-2008, 03:38 AM | #17 |
Chevy nut
Ok to answer my own question of will it work...Yes it will! I took the whole front suspension and the steering box and P/S Pump. The engine cradle lined up perfect and there was two holes that didnt line up on the top so I will drill them out tomorrow. I loosely fit everything up to see how everything will look. Now I am wondering if I should grab the power brake booster off there and see if that will fit so I will have updated brakes too!
Heres some pics! I hope this will help the next person that thinks they want to do this!
05-27-2008, 04:12 AM | #18 |
Brake booster isn't quite a bolt in, but Krue I know for one did it, so you might PM him and see what it took. It will definitely be helpful.
05-27-2008, 05:13 AM | #19 |
variable rate is where the center, say 1/4 turn past center in each direction is slow turning... the amount of steering you do 95% of the time when at speed, then the rest of the turning past that 1/4 turn cranks the wheel faster, like a quick ratio box.
You get the best of both worlds. |
05-28-2008, 04:25 AM | #20 |
Chevy nut
Yeah the brake booster is a bust. Nothing lined up. So I am going to stay with the standard brakes.
05-28-2008, 09:05 PM | #21 |
Were they all variable ratio from '73 on?
05-29-2008, 12:03 AM | #22 |
from my understanding, yes.
