Old 05-22-2008, 01:47 PM   #1
69c10step
69c10step's Avatar
Strong antifreeze smell
After I drive for ten minutes or so, I get a smell of antifreeze inside the cab. If I turn the truck off for a few minutes, when I start it back up, the smell is the strongest. I can't see anywhere that it is leaking; there's never a puddle; no smoke from the exhaust; nothing dripping inside from the heater core. It doesn't seem to matter whether the heater is on or off.
Any thoughts?
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 05-22-2008, 02:24 PM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Strong antifreeze smell
You might want to check the heater core.It really could be the only problem,for thats the only source inside the cab. good luck
bigsnookmaster is offline   Reply With Quote
Old 05-22-2008, 06:12 PM   #3
69c10step
69c10step's Avatar
Can I just bypass the heater core by connecting the two hoses together or removing them all together and plugging the holes?
Old 05-22-2008, 07:20 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Sure. And if the smell goes away,you know it's the heater core OR just one of the hoses inside the cab,maybe even a loose clamp.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
