PITbut
big block driveline???
The truck is a 71 SWB stepside. Came with a I6 in it.. Im installing my big block shortly and i need a new driveline. Now, since im useing stock BB engine mounts, cant i just purchase a drivline for a BB chevy of that same year make with a TH400 transmission????
Thanks for the info. |
its all about the +6 inches
Re: big block driveline???
In theory yes.
However, odds are slim that you'll locate a SWB with a big block. It'd be much quicker to call your local drive shaft shop, have them tell you how they want you to measure it (make sure your ride height/weight is about right) and have them make you one. |
![]() Join Date: Jan 2002
I would try for a one piece, too. It bypasses the hassle of the bearing going out.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Measure from the hub coming out of the rear end to the tailshaft of your transmission and take that to your local reputable driveline shop. It shouldnt cost more than $150-$180 to have them make you a new one from scratch.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
To add to that... make that measurement with the suspention loaded, and the yoke 1/2 way in, 1/2 way out of the tranny.
That is the driveshaft industry standard... but once in a while, you'll get some idiot that does it another way, so get the info fromt eh dude doin the work. You could also take your measurements, and spend a day in the junk yard... but it'll probably need U joints and just isn't worth the work IMO. |
PITbut
Any tips for an air ride suspension.. Do i measure with it fully dropped or fully inflated?
#7 | |
As for bags, I have never used them. But, it would make most sense to measure at ride height.
Talk to them. They may recomend a 2 piece shaft
PITbut
That tranny is set up for a 2 piece shaft. There is a slip in the center of the shaft.
You'll need to convert your trany to a slip yoke. |
![]() Join Date: Apr 2005
The piece that goes into the tranny is called the slip yoke, it will slide in and out as the rear suspension moves. As far as air ride, if you have a serious drop, you may want to go with a 2 piece because it will minimize the pinion angle change. Here's a picture of my setup for my 69 Burb.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#12 | |
PITbut
#13 | |
#14 |
PITbut
#15 |
Nope, on the 400 the toke bolts to the tailshaft on some and a slip on the others. Get a DS from a newr model truck and have it cut down to fit your truck. You can take the bolt on yoke out and install a slip yoke (you'll need to do this if you want a one piece shaft) or stick with the bolt on and get a two piece shaft with the slip in the center of the shaft. I don't do air bags, but I'd guess a mesurement fully air up and air out would let the driveshaft shop figure out if a one or 2 piece shaft is needed as well as the length.
#16 | |
PITbut
#17 | |
PITbut
#18 |
Yeah, sorry the th400 was used as a heavy truck trans, so it can be bolt on yoke or slip if it was a car trans or the like. Call a Driveshaft shop and tell them what you are doing, they will tell you where to measure from (I have been told 2 or 3 different places by different shops, so I think it is a matter of each guy's preference) The used shaft will help in that cutting one down is way cheaper than building one. The late model trucks have beefy driveshafts. Hope this helping and not confusing ya!?
#19 | |
PITbut
#20 |
Yep, they can cut it down to fit if you want/need a 2-piece, but I was suggesting a late model one piece for the donor to be shortened into a 1-piece. The yoke thing is funky on the 400 as it came both ways, but usually as a bolt in on a truck cause the mostly came with a 2-piece when a 4oo was used (heavy duty, usually means longbed).
#21 | |
PITbut
#22 |
Yes, as the rear end moves up and down in suspension travel the DS has to get longer and shorter. If a one piece, the slip yoke will be in the trans, on a 2 piece there will be a slip shaft in between the two piece of DS. Make sense? Sorry if I am confusing ya, picts would be easier but I dont have any?
#23 | |
PITbut
#24 | |
http://www.iedls.com/twopiece.html I think it even tells you how to measure them.....
#25 |
That looks like the ticket. I am not into 2-piece shafts, but a good aftermarket one would be the ticket behind a BBC with bags.
