Old 05-23-2008, 04:04 AM   #1
prg machine
prg machine's Avatar
glove box hinge and spring
can anyone tell me or post a picture of how the hinge and spring go together for the glove box door?
It has beelong time since allof mine was together and i didn't take a pic like I should have would have etc.!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-23-2008, 05:37 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: glove box hinge and spring
If you don't get a response with a pic, I'll see if I can get one for you tomorrw (too late tonight).
68gmsee is offline   Reply With Quote
Old 05-23-2008, 05:44 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Hell- I'm up here in St.Helens (a.k.a.- "Banjo-County") and I have an extra hinge already assembled just layin' around that I'll give ya'....just let me know. But if you really want to experience the satisfaction of putting your's back together- I'll post up a pic later tonight.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 05-23-2008, 03:24 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey prg machine....
I got this from LMC....one of the only things they are good for....
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=47
hope this helps!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-23-2008, 03:41 PM   #5
prg machine
Originally Posted by gcburdic View Post
Hey prg machine....
hope this helps!!!
Thanks, that diagram helps..............I was more interested in the spring wire assembly to the hinge that I believe opens the lid when the button is pushed. Am I assuming right?
383 .040 over
Old 05-23-2008, 04:45 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Hope this helps... I took a couple of others if you need more. The spring on mine sort of assists but I believe the little rubber nipples on both sides and the actual weight of the door does more to open it than the spring.
Old 05-23-2008, 06:50 PM   #7
prg machine
Perfect. That picture is exactly what I needed.
Thanks a million!
383 .040 over
