Old 05-23-2008, 04:13 AM   #1
coggonobrien
home made multi port???
does somebody out there make a simple do it yourself efi kit? I had an idea to take an old tunnel ram and drill/tap the lower runners for fuel injectors then put a pair of dummie carbs on top to act as throttle bodies. Just wondering if there is a kit out there that will let me do this.
thanks, Dave
coggonobrien is offline   Reply With Quote
Old 05-23-2008, 04:37 AM   #2
ed2552
ed2552's Avatar
Re: home made multi port???
That would take a LOT of work, you would have to have the carbs wired up for TPS, etc, that would be a lot more expensive than a regular EFI system
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
