Old 05-23-2008, 05:59 AM   #1
cmcolumbus
cmcolumbus's Avatar
center carier bearing
Hay has any body had problems with the carier bearing.
I chainged mine one year ago and it faild. Is there a better pruduct out there.
I could not find a better one so I went with same style bearing.
Hear are some pic's.
cmcolumbus is offline   Reply With Quote
Old 05-23-2008, 06:28 AM   #2
dan42
dan42's Avatar
Re: center carier bearing
Check out this thread -
http://67-72chevytrucks.com/vboard/s...d.php?t=229826
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-23-2008, 08:37 AM   #3
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Is that bearing from Federal Mogul?
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 05-23-2008, 02:11 PM   #4
caminokid
Chevy nut
caminokid's Avatar
I wonder if you can eliminate it totally and use a newer drive shaft? I have been thinking about this for awhile now.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 05-23-2008, 04:23 PM   #5
cmcolumbus
cmcolumbus's Avatar
I was told that putting a single shaft on a long bead will not work.
Old 05-23-2008, 04:36 PM   #6
cmcolumbus
cmcolumbus's Avatar
Thanks for that tread dan42 I will oder mine today.
Old 05-23-2008, 05:48 PM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Check your trans and motor mounts, If they are bad, they will take the carrier with them
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-24-2008, 03:26 AM   #8
caminokid
Chevy nut
caminokid's Avatar
Its was a thought. All the 73 to 87 1/2 tons use a single drive shaft. My 87 lwb 1 shaft.
Old 05-24-2008, 06:06 AM   #9
rick0312
rick0312's Avatar
also, maybe a good Idea to have the drive shaft balanced.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
