Ignition switch
I just bought a 56 so I'm new to these trucks. Before I buy a new ignition switch, I wanted to confirm that there is supposed to be a spring inside to return the key to on from the start postion. Mine will stay in the start position unless it's turned to on. Seems obvious but maybe they didn't come up with this until later years.
Yellow truck club
Re: Ignition switch
Welcome to the forum.
Mine springs back to on. I think there would be a lot of burned out starters if it didn't.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Re: Ignition switch
Just double checking, thanks for your help.
Hollister Road Co.
Re: Ignition switch
If its original with a pedal start it has on and off and acc, it won't spring back. Electric start had a acc, off, on and start and it sprang back to on. You want a switch for an electric start truck such as a V8. There were very few electric start 6's. If your staying with a pedal start then the type of switch you want is a pedal start ignition switch.
Re: Ignition switch
It seems to be original, the bezel says off, on and start. It works properly except for no springback. I would like to find an original style switch with the acc position.
