People know me
shifter linkage?
I just converted my 72 blazer back to a automatic. Is this the right shifter linkage for my th350? Can someone post some pics of how it is installed?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Re: shifter linkage?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#3 | |
Ecited by mod IAW the rules you agreed to when joining.
Specificly; Quote:
its all about the +6 inches
lets not turn this into a parts thread lindsey. This isn't the right forum, and you aren't a subscribed member.
People know me
can you guys not see the pics? there is not clutch linkage, it was all hydro and it all went with the tranny when i sold it.
Retired Air Force Veteran
![]() Join Date: Aug 2007
BigBadChev72 sorry for cutting in but I'm also having a similar problem.
Andy, Thanks for the parts break down. I'm also having difficulties lining the Z-bracket up with the linkage bracket. My ride, a 69' GMC StepSide w/ Turbo 350 Transmission. Seems the GMC frames are slightly different than the Chevy frames. Found this out when doing a rear end leaf to coil conversion. When it was all done, I had to add a hole on each side for the upper coil cup to mount. Yes, there is a difference. Same problem seems to be the problem for the tranny linkage. Was/Is/Could this be because the frames are slightly different? Your illustration shows 70'-72' breakdown. I want the column shift but seriously consider going with an automatic floor shifter. HERE'S MY LINKAGE. CORRECT FOR A 69' GMC? The 3rd piece with the spring is installed on the tranny already. ![]()
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 05-24-2008 at 02:41 PM. |
People know me
Crap, Looks like i got the wrong shifter deal that bolts to the tranny, is there a place online that sells just that piece?
Check with board members/vendors: teeitup, billsbowtie or uncle. One of these guys should have what you need. Good Luck
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
harry, it sounds like you may have the engien in the wrong location. If you want to keep it there, or if something else is 'off' for what ever reason, you could simply drill new holes and move the piece that bolts to the frame rail so it does line up.
Funny you bring that up. Somebody said that. Drilling new holes may not be a great idea because the bracket does not sit flat on the frame. A hole where the e-brake cable is in the way. Motor is gonna be pulled next W/E. Anyway, Thanks Andy.
