Will 73-87 GM tow hooks bolt to 72 K5
Will oem 73-87 GM tow hooks bolt to 72 K5?
Thanks in advance. ...Dan |
Has anyone used tow hooks from non-67-72 trucks?
I am looking for something that will bolt up with out mods. Thanks. ...Dan |
I can't answer your question, but here is a photo of a tow hook on my 72 that may help someone else answer your question.
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
Thanks M.
...Dan |
Not a bad nut after all..
The difference between the '73-'80 GM tow hooks and the '81-'87ish is that the earlier ones are much beafier. I've seen the '73-'80 tow hooks on our trucks, but they get too close to the spring perch/spring IMO (there isn't enough room to slip a rope on anymore). I like MStokes' solution, but would add one of those little sheet metal springy clips to keep things from slipping off the hook.
