front fender gaskets?
I have ordered up a set of the front fender gaskets ,as they are called, from Brothers Truck. Does anyone have a picture of how these mount up? Are there any anti-squeak rubber shims or the such that mount up under the mounting points of the fenders to the cab?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: front fender gaskets?
anyone??????
ttt
I have not heard of fender gaskets. Can you describe them and let us know where they are used?
The only thing that comes to mind arre the fender to cab seals. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I believe that is what they are brothers calls them "dust seals" also
there are big ones that are shaped like the rear of the fender and smaller ones that look like a large circle about the size of a plum.......anyway here is a picture of them
sorry..... kinda blurry. I guess i will fi9t them up and see if i can figure them out tommorow. The small ones confuse me..............do they fit at the fender to cab location also?
prg machine
I am unsure of the small round ones but the larger ones I have seen on a few GMC's and I think I heard they were used on Blazers. There is a metal bracket that the rubber is attached to (with staples) that is no longer produced Someone on this board made up a few Left and right metal brackets and was offering to make and sell them a while back. Installation is: Basically you take the seal and attach to the bracket that is attached to the cab with small metal screws in the area between the back of the fender and in between the door. It was a way to keep the dust out of the door hinge area From what I have seen they are kind of rare as not all trucks have or had them Hope that helps
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
Maybe it will help. My c10 has them.
From what I have seen there is no rhyme or rhythm to the trucks that had them. They don’t really serve much purpose and are a pain to install on the original brackets and I have heard they can rub spots on the paint if not done absolutely correct. I would not use them. JMO.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Chevy nut
Out of all the trucks I have worked on...I dont remember ever seeing them on them.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
very interesting...............................and here i have a set and wondering if i will even use them now?
#13 |
![]() Join Date: May 2008
If You Dont End Up Using Them Send Them My Way They Are Factory To My Truck. So Let Me Know If You Need To Get Rid Of Them...thanks
#14 |
I just sent a PM to ya Forever71
#15 |
2WD Jimmy
![]() Join Date: Mar 2005
They came on my truck. It is a 72 Jimmy 2wd with Cheyanne package and air (if that means anything). Since the lower part of the cab was replaced in that area during paint, I had to locate and drill holes for the new rubber. I just posted this topic about 2 weeks ago. I had a gentleman from this forum tell me they only came on air trucks... that 69CST above puts the end to that theory. Im still thinking of taking them off. I just wanted them on for authenticity. Most of my buddies just laugh at me for that because of my drivetrain. Its altered some.
#16 |
CST/ Cheyenne/Super/Sierra/Grande had them originally, they serve to seal engine compartment heat and dust similar items on new model trucks. The small "plum" shaped pieces mount one at the top one at the bottom of the metal bracket. The staples that are sent with them are a pain in the a** to use, I use a heavy staple like you might use to hold insulation in place in your house. They are side specific so you should lay them out and look at the old ones if possible for reference if nt be sure you look at the brackets as I think they are marked left and right. Hope this clears up any confusion, if not I can get some pictures tomorrow. Not found "only" on air trucks but upper option package trucks.
#17 |
Not a bad nut after all..
My '72 Sierra with air has them.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#18 |
Classic Parts has them... looks like "Deluxe pickups only" here is their description...
"Die-stamped rubber seals that fit between the rear edge of the front fender & cab. Originally used on deluxe pickups only." http://classicparts.com/prodinfo.asp?number=37-615
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
#19 |
I have pics of them installed with the fenders off so you can see how they mount I can email to someone to post
#20 |
![]() Join Date: Jul 2005
Send them 2 me I'll be glad to use them. Larry
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
#21 |
I checked the link to the ones pictured on Classic Industries..................................Brothers only shipped me 2 of the ovals and NO staples.....................I hate to pass on a problem to someone else. I am going to call Brothers and send them back.
#22 |
The following good pictures are credit suville:
#23 |
now that I see it...............................no thanks!..
My truck can live without this fit up nightmare! I have enough trouble just getting the darn fenders to line up straight...............my truck never had em..............I don't have the bracketry.............Brothers didn't send all the parts.............etc. etc. etc. life is too short to try and figure this one out! ![]()
