Old 05-24-2008, 07:23 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Where to read vacuum?
Finally got my vacuum guage working yesterday. They put the needle on backwards. GRRRR. Anyway, I hooked it to the other side of the carb, the one I'm not using for vacuum advance. Will that be ok? Not sure if its full vacuum or if it will be inaccurate.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-24-2008, 07:31 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Where to read vacuum?
you should have it connected to the intake manifold.
for reading....the lower the vaccum reading, the more fuel your engine is burning.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-24-2008, 07:41 PM   #3
red71cheyenne
Back in the sticks
Hmmm, just looked thru my carb manual and it says the port I'm using for the vacuum advance is ported for emissions. The other is full vacuum. Am I running the right one? I'll get a vacuum fitting for the vacuum guage that comes off the manifold then.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-24-2008, 08:45 PM   #4
LONGHAIR
You should have both connected to full vacuum. A simple "T" fitting will do what you need. You probably have to slow your idle down some when you move the vacuum advance to full vacuum. It will pull in the advance and cause it to speed up some.
LONGHAIR is offline   Reply With Quote
Old 05-24-2008, 11:04 PM   #5
cruiserman
It's a can of worms. Some folks prefer ported vacuum, and some prefer manifold vacuum. I'm running manifold vac.
Hook the vac gauge up to the intake.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 05-25-2008, 02:53 AM   #6
LONGHAIR
There is no good reason to run ported vacuum. It is "old technology" that was really just an experimental "band-aid". It was part of the first "emissions conformation" tuning in the late 70s and early 80s. The "late" timing at idle increases exhaust heat, which help burn hydrocarbons and helped the catalytic converter work better...but it does nothing for performance or drivability.
Old 05-28-2008, 11:11 AM   #7
red71cheyenne
Back in the sticks
Thanks guys. Didn't get a chance to swap over to full vacuum, had to fly back to Japan on Sunday. I'll mess with it at Xmas though.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-28-2008, 01:15 PM   #8
cobb_ben
cobb_ben's Avatar
I always hear that it's good to read it at the base of the carb on full vacuum port!
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
