Old 05-24-2008, 09:11 PM   #1
jwart
dash removal 65 help
hey anyone outhere right now got 65 fleet am stuck at kids farm watching animules for memorial weekend. lost all rear lites on trip up here starting to run new wiring harness i brought as long as i'm stuck outhere by myself. got all face screws out of dash panel & bolts to column support my dash seems to have another anchor point over top of column but can't find anything. got real bad back so i'm only good for short time under dash. any help appreciated
jw + art = jwart
jwart is offline   Reply With Quote
Old 05-24-2008, 09:15 PM   #2
David Flores
David Flores's Avatar
Re: dash removal 65 help
about 25 spot welds you will need to drill out where the dash meets the windshield
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 05-24-2008, 09:18 PM   #3
jwart
should reword that i'm just trying to get out gauge cluster faq keeps giving me stuff on 67 to 72
Old 05-24-2008, 10:06 PM   #4
LILRED66
LILRED66's Avatar
The gauge cluster is held in place with five screws in the bezel, holding it into the dash sheet metal. You will also need to remove the wiring from the back of the head light switch, wiper switch, ignition switch, cigarette lighter and the choke cable, as well as the speed-o-meter cable, oil pressure capillary line and unhook the dash wiring harness, in order to get the cluster out of the dash. When everything is removed, it will tip out of the opening.
I hope this information is helpful and good luck with removing it.
LILRED66 is offline   Reply With Quote
Old 05-24-2008, 10:29 PM   #5
jwart
thanks for replies so far everyone. done all above, but it is SOLIDLY hung up in area over top of column. all screws on outside of bezel came out (biligerently?) wanting to twist bottom of dash cross section below bezel probably never been off just open to suggestions. have had to use heat on every bolt so far on truck. don't want to try that & melt face plate. brought this one out of 11yrs. in weeds with more rust than anyone that has seen it would be willing to tackle - major windshield leak for quit a while, she just made a 4 hr. road trip up here & my way home so i ain't giving up thanks again everybody & enjoy this long weekend
jwart
Old 05-25-2008, 12:52 AM   #6
kevindtimm
In my experience with these dashes panels, there is a little bump in the daash iteself that holds the panel in. I had to use a skinny screwdriver between the dash and the panel to get it to pop out. It's REALLY scary the first time, but once you've done it, it's better the next time(s)
Just go slow, it'll come.
kevindtimm is offline   Reply With Quote
Old 05-26-2008, 03:37 AM   #7
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
in my 65 i had to take the speedo cable out before she would budge
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 05-26-2008, 05:58 AM   #8
billydonn
Council of the Elders
billydonn's Avatar
Ignition switch, lighter, headlight switch and all that stuff must be removed.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-26-2008, 08:17 PM   #9
jwart
manual choke cable anchor nut is just to left of steering column hits partially onto dash opening on this truck. this & headlite switch are only ones having to come out to tip it out on mine, BUT the problem was the divider between plegi cover & gauge panel were very rough trimmed & hanging up on burrs on inside of dash panel cutout. pried enough to get top out to see what was happening. old harness out & new one started going in. cleaned , painted. & installing tach into panel now. painted from behind to show all exposed metal hanging me up & ground over edge of counter to keep straight. hope this helps anyone else that may find same problem. may be can be added to tach FAQ thread. thanks for everyone that took time to help with advice.
jwart: MEMORIAL DAY REMEMBER ALL THOSE THAT HAVE & ARE FIGHTING FOR OUR RIGHTs & TO PAY $4. GAL remember gas wars = .12cents gal
:NEVR LOK BAK
