11-06-2002, 11:01 AM | #1 |
Posi rearends
Can anyone elaborate on the differences, if any, between a posi from a leaf spring rear end and a coil spring rearend?
Someone on the board has a rear end from a 70 leaf spring, and I have a 70 coil spring. |
11-06-2002, 11:09 AM | #2 |
Differences are in the mounting, the internals will swap.
Jim |
11-06-2002, 06:37 PM | #3 |
Fabricate till you "puke"
if you dont mind a little welding http://www.classicperform.com/produc...ersion-Kit.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-06-2002, 07:28 PM | #4 |
ok crazy longhorn. Wheres the kit to go thre other way? (from coil to leaf)
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
11-06-2002, 07:39 PM | #5 |
11-06-2002, 07:42 PM | #6 |
thanks Dude!
11-06-2002, 07:52 PM | #7 |
the shock mounts for the leaf rear shouldnt be too bad to build, or you can cut em off an old diff. good luck
11-06-2002, 10:08 PM | #8 |
jimkshortstep4x4,
Thanks, I should have elaborated a little more, because you are the only one that understood what I was trying to say. I am interested in the carrier, ring and pinion, and the axle specs(i.e. 30 spline). Are you saying that a 12 bolt truck, 3.73 posi, carrier and ring and pinion, is the same regardless of leaf or coil spring. |
11-06-2002, 11:53 PM | #9 |
70 longbed, sorry i misunderstood the post......the internals will swap as Jim posted(30 spline axles). if you have a 70 diff, the 71-72 axles should swap (if you want 5 lug). the 67-69 housings & axle shaftes were a little narrower. as far as carriers, the 3.73s are on a 4 series carrier (3.73 & lower). the 3.07s are a 3 series carrier (3.07- 3.42?)....... the posi will swap with an open carrier, if the same series.
