Old 11-06-2002, 11:58 AM   #1
hanssolo
hanssolo's Avatar
Brake line touching exh. pipe question
I know my brake line at one point it touchs a header pipe. I know it should'nt but does anyone know what can happen? I would think the fluid would expand a little is all. Or does it get foamy?
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 11-06-2002, 12:00 PM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
could prolly boil it or cause the expansion to get nasty and maybe trip the brakes... dunno for sure
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 11-06-2002, 12:22 PM   #3
JimKshortstep4x4
Smile
Most brake fluids can survive high temperatures, (over 200 degrees F), but I would be very concerned about the very real probability of the contact abrading/corroding the line and causing a leak. I would suggest getting the line to clear.
Jim
Old 11-06-2002, 12:28 PM   #4
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
not to mention the possibility of the brake line getting crushed by a good bump from the exhaust. my exhaust swings back and forth on my ford enough to have dented 3 inch tubing.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 11-06-2002, 12:40 PM   #5
Piston
Piston's Avatar
On the left side I bend the lines back about 2" and tuck them back behind the crossmember.
A great suggestion from Mark25 is to use heat shielding around these brakelines to keep the heat off them, also providing a little protection from rubbing.
http://store.summitracing.com/partdetail.asp?part=3012
Piston is offline   Reply With Quote
