Old 05-26-2008, 04:40 AM   #1
prg machine
prg machine's Avatar
Doing the front fenders
Yep, right in the midle of all the fun of hanging those babys and I look down to the upper rear quadrant where I see the nice neat tidy holes for my fender badges ( the bowtie with the 20 benaeath it) and I realize that I don't have access to the rear to put the retaining nuts on!!!! So after I get all of my body work done and painted it looks like I need to remove the fender part of the way to get my hand back there.
What is the usual procedure for doing this?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-26-2008, 04:55 AM   #2
chevy72blu
chevy72blu's Avatar
Re: Doing the front fenders
I cant help ya man.. I just wanted to say sorry for your "D'oh!" moment. I had quite a few of those the other day bolting things up backwards and what not =P
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-26-2008, 05:14 AM   #3
prg machine
Not realy too concerned since the fenders are in primer on the outside. I only painted the inside. I am doing the entire exterior of the body as an "assembly" to get a good color match. So the badges can't realy be on there as of yet anyhow . I was just a little surprised to find out that the whole dang fender has to come practicaly off the darn truck just to put a side emblem on!!!!
What do most normaly do ahen painting the truck without dissasembling. ???? I don't see masking as an option here.
383 .040 over
Old 05-26-2008, 05:55 AM   #4
1967C20
Junior Member
1967C20's Avatar
Maybe drop the inner fender?
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 05-26-2008, 05:59 AM   #5
Green Machine
Green Machine's Avatar
Three ways to do it, it is possible if your arm is skinny enough to reach up there and get the nuts on, or loosen the bottom bolt for more room. Easiest way is to get some barrel clips, the same ones that hold the center tailgate trim on, push them in from the outside and push the trim on. I've done it all three ways, and the barrel clips are the easiest.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-26-2008, 09:12 AM   #6
prg machine
Who has the "barrel clips" ................Brothers truck maybe?
Do you have to drill out the holes larger?
So I just buy the barrel clips that hold tailgate trim and that should do it?
Sounds a lot better than taking all of this stuff apart that took all afternoon and a buncha tweakin' to get together.and it ain't even aligned yet.. Gotta do the other side tommorow!
Boy it's fun! ( gotta keep tellin' myself that when doing things like fenders!!)
383 .040 over
Old 05-26-2008, 09:22 AM   #7
prg machine
I googled and found that Classic Industries sells puh in barrel nuts just like you say...................they come in different sizes for different size studs.
This sure simplifys the whole thing.. I realy didn't want to think about taking those fenders back apart after the final paint job!!!!
383 .040 over
Old 05-26-2008, 06:27 PM   #8
mbgmike
You buy the clips at most all paint and body shop supply places.
mbgmike is offline   Reply With Quote
Old 05-26-2008, 06:45 PM   #9
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Doing the front fenders
I thought about this and here is what I did
#1 I waited till I had my truck painted wet sanded and buffed (DONE)
#2 I screwed the speed nut's up on the peg's of the emblem's a couple time's to make the thread's (NEW EMBLEM'S)
#3 I took a drill and correct size drill bit and drilled away the paint from the emblem hole's on the fender's
#4 I put JB weld on the peg's pushed the emblem's in place put a peice of tape on them to hold them till the JB weld dryed ,
#5 removed tape next day
that was two year's ago and have never had a problem , when I need them of for another paint job I will just heat up the JB weld with a propane torch and remove the emblems , then put them back on the same way again ,
I figured this out on my 67 camaro because rubber man could not get in there to put those nut's on with the fender installed , so this trick work's great dosen't hurt anything and let's you bolt your fender's up align them without having to take them back off to put the emblem's on ,,,,,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 05-26-2008, 08:25 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Been there, done that... About 10 years ago I did that on my 69. Sat there an coulldn't believe I was that dumb...
I don't remember if I took the whole fender off again. I'm more inclinded to think I removed the wheel well inner fender.
My .02 is doing it right and take your lumps...
68gmsee is offline   Reply With Quote
Old 05-26-2008, 08:55 PM   #11
prg machine
Good philosophy.............doing it right does p[ay off down the road....................those barrel nuts sure seem like worthwhile looking into anyway
383 .040 over
Old 05-27-2008, 04:39 AM   #12
Green Machine
Pretty sure the ones I used were 1/4 inch size, need to carefully clean the paint from the holes with a drill bit, 1/4 inch again I think, else it will be too tight.
Old 05-27-2008, 07:43 AM   #13
Frizzle Fry
Frizzle Fry's Avatar
Thanks for sharing that PRG. Saves me the headache ...if I remember by that time
Frizzle Fry is offline   Reply With Quote
