Hey guys I recently completed the front suspension rebuild. In the process I converted to disc brakes and replaced all suspension parts. I wanted to forward you guys the part numbers just in case it might help someone on the forum. I bought all the parts from the local O’Reilly Auto Parts so you could even order parts online though them. I bought drop spindles and springs through Mike’s Bump and Grind Garage in Webster, TX, he has a website.
Here are the parts and part numbers I used for the conversion: 2 ˝ inch drop McGaughy Spindles 1 inch drop McGaughy Springs New front suspension parts: Pitman arm K6131 39.99 Idler arm K6096 15.99 Ball joint (2) K6024 14.39 each 28.78 pair Ball joint (2) K6023 12.47 each 24.94 pair Tie rod end (2) ES370R 11.51 each 23.02 pair Tie rod end (2) ES350L 11.51 each 23.02 pair Control arm shaft (2) K6098 28.79 each 57.58 pair Control arm shaft (2) K6147 33.59 each 67.18 pair *** I used the low-end house brand, but all of them had grease fittings. I was told by the employee, sometimes the same part numbers of the low-end parts will or will not have the fittings, and might be slightly different in appearance. So, if you choose to go low-end, I would suggest buying from the store not online. Check each part to make sure they match, (Ex: ball joints, tie rod ends) and have the grease fittings.*** I did not buy sleeves from either place. I also returned the outer tie rod ends and went with newer model ones because of the sleeves I ordered from CPP. I did have to drill out the hole on the spindle for the tie rod end.*** Disc Brake conversion parts: Rotor (2) 81-60258 29.39 each 58.78 pair Brake caliper 18-4038 24.69 Brake caliper 18-4037 24.69 Disc pad set EC52 25.11 Wheel seal (2) 8871 1.69 each 3.38 pair Brake hose (2) BH380712 20.10 each 40.20 pair Dust cap (2) 13977 3.59 each 7.18 pair Spindle nut (2) 04993 4.99 each 9.98 pair Bearing (2) A3 7.49 each 14.98 pair Bearing (2) A6 6.91 each 13.82 pair *** verify bearing part numbers before you buy. I remember I had an issue with the inner, but I think it might have just been the kid working there gave me the wrong one but had charged me for the correct one.*** |
| Bookmarks |
