engine...
.030 over is a 355 right?
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
![]() Join Date: Feb 2007
Re: engine...
yep
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: engine...
thanks...
Re: engine...
I never knew that.For some reason I thought it was a 400 with a 350 crank.I`ve never heard a bored 350 called anything but a 350 bored .xx over.I guess that`s because they either said 350 bored .30 over or called it a 355.
Re: engine...
A stock bore 400 (4.125") with a 350 (3.48") crank gives you 372 (+.030= 377)
The formula: bore x bore x stroke x .7854 x # of cylinders |
![]() Join Date: May 2002
Re: engine...
As long as it uses the stock 350 crank.
Use a 400 crank, and you've got a 383. ![]()
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Chevys Kick A$$
Re: engine...
Yea that sound right.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#8 | |
Re: engine...
Re: engine...
lol... yea I figured out the 383 but I never really knew the 355 until I actually calculated it the other day... cool now I can say I have a 355!!!
#10 | |
Re: engine...
#11 | |
Re: engine...
Re: engine...
It was just as "tongue in cheeck" as yours.....LOL
#13 |
Re: engine...
I never did the figuring.I just never heard anyone call a motor anything other than what it started out as plus what oversize they put on the bore until recent years.I always figured by renaming the motor meant it was a custom build,such as changing stroke by swapping cranks/rods.I just learned something,though.Guy`s shave heads,cut tops off pistons,bore,stroke...You almost have to follow a displacement figure with how you got there.
You can completely build a motor and not know what the actual displacement is.You still need to know math,though. ![]()
#14 |
Formerly ADHDCARGUY
Re: engine...
Generally when asked about the engine in the "Pink Thing", I'll say 355. If they say, "never heard of that" , I'll tell 'em "that's a 350 bored .030". They say "oh". Asking questions, that's how I learned most of this stuff. I realize now, as a young teenager, I drove the older guys in the neighborhood crazy with questions.
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
