![]() Join Date: Aug 2001
They came off the new Hummer H2s The Specs: Offset is the distance from the centerline of the wheel to the
mounting surface so the centerline on an 8.5" rim would be 4.25" plus 18mm (.70") comes out to a backspace of 4.95". The center holes are actually 4.5" in diameter. and the stud centers are 6.5" So will they fit on my GMC 3/4" ton? |
Pic 2
#2
Hot Rods For Life
I think they should. Don't quote me. The new H2 is based of the Suburban platform.
Livin' it up.
![]() Join Date: Nov 2001
i believe they should, that's how i've seen a bunch being sold.... but i could be wrong. center cap however wont work on a FF rear i dont think, the cap wouldnt jut enuf.
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
I've checked into these and the best I can tell they will fit, but no guarantee.
You are aware the center cap says "HUMMER". It's tough to make out in the photo on Ebay. |
Center caps would not fit anywho but, trying to find a decent set of 8 lugs under 500.00 is hard to find. They look really cool without the caps. Now if I really had the bucks I would go for the Chromers
They will fit, except for the center caps as noted above.
Tim |
