Old 05-27-2008, 01:39 AM   #1
dan42
dan42's Avatar
door adjustment -
Does anyone know if it's possible to adjust the door hinges that attach to the body while the door is on? It's a PITA to take it off- I would think there would be a special wrench or something...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-27-2008, 02:14 AM   #2
463
463's Avatar
Re: door adjustment -
here is a link to a door wrench photo http://images.google.ca/imgres?imgur...%3Den%26sa%3DN
Trueman
463 is offline   Reply With Quote
Old 05-27-2008, 02:44 AM   #3
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I made couple wrenches with a torch and some old 9/16" comb. wrenches. Looks similar to the pic in the above link, just a shorter version.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 05-27-2008, 07:56 AM   #4
dan42
dan42's Avatar
Hmmm. Linky's expired. I think I'll just pull the door for now and guess where they should be - looks like a handy tool, though.
Philippians 4: 6-7
Old 05-28-2008, 06:26 AM   #5
463
463's Avatar
still a good link
Trueman
Old 05-28-2008, 07:19 AM   #6
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
I have a suggestion for you before you pull the doors, hopefully you have'nt before you read this. Get a drill and a 1/8" drill bit, open one of the doors, drill a hole through the UPPER hinge and into the door frame, then do the same to the lower hinge. Of course you need to make sure that the doors are lined up before you do this. Then after all body work and paint are done all you have to do to put the doors back on is stick that same drill bit back into the holes you drilled, bolt it up and the doors should be lined up. Any questions?
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
