Old 05-27-2008, 03:21 AM   #1
apachedaddy
apachedaddy's Avatar
need a little lowering help
Ok guys, i want to order a lowering kit to be there for when i get home in july from iraq. did a search and found plenty of stuff but my real question is how low can i go without doing a bunch of mods on a statis drop. i know i will prob need a adj trac locator and i can do a c-notch if needed. just wanted to know how much i can go and have the truck sit level. any help would be great. thank you for your help.
apachedaddy is offline   Reply With Quote
Old 05-27-2008, 05:38 AM   #2
scotts62
One day...
scotts62's Avatar
Re: need a little lowering help
What kind of truck?
Scott
93 crew cab build
Project 62
Old 05-27-2008, 07:31 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
Looks like he has a 66.
You can do 3" drop springs and 2.5" spindles up front, and 6" drop springs and whatever size block you want in the rear. 1.5" blocks would get you "level" at a 5.5/7.5 drop ...assuming you don't have leafs. You'll definitely want the adjustable track bar (I like the ECE super track bar for it's longer bar), C-Notch, and shock relocators at that point.
Frizzle Fry is offline   Reply With Quote
Old 05-27-2008, 07:41 PM   #4
SIR
SIR
SIR's Avatar
.....this has a 4/4 drop,actualy 3 1/2 in front but it did settle just around 4" hope this helps come home safe...and thanks.......
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 05-27-2008, 10:45 PM   #5
joe231
joe231's Avatar
hey sir, what size tire you running?
CHEVY ONLY
Old 05-28-2008, 01:59 AM   #6
apachedaddy
hello again, sorry for the lack of info yes its a 66 short/fleet. no leafs trailing arms set up. have not even though of rim tire combo as of yet. Just want to do a good drop without doing any crazy front end mods and keep it level. was thinking of the grand slam kit from CPP because i wouldnt have to try and piece anything together. If anyone knows of a better kit out there please let me know. and thanks for your support.
Old 05-28-2008, 06:32 AM   #7
SIR
SIR
SIR's Avatar
....255-60-r15 on torq thurust-o 15x8-1/2 .......
Old 05-28-2008, 03:25 PM   #8
joe231
joe231's Avatar
thanks for the info
CHEVY ONLY
Old 05-29-2008, 05:33 AM   #9
Dadsredwagon
Dadsredwagon's Avatar
I just did the CCp kit, it comes with DOstech shocks , not sure if they are the best, others will chime in , I just installed mine , use lots of PB blaster non th ebolts for sure...mine ended up breaking , but it worked out ok
Dadsredwagon is offline   Reply With Quote
Old 05-29-2008, 03:14 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out ECE (Early Classic Enterprises) for some great kits, products and service. On their site they have a page with drop stance photos with various drops, which will help give you a good idea on what you can expect.
Good luck with the project, and thank you for your service! Make it home safe!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
