Old 05-27-2008, 05:14 AM   #1
northerngmc
northerngmc's Avatar
Power Steering Identification help needed
My 1969 GMC 1/2 ton has about 1/4 to 3/8 of a turn play in the manual steering box. I am considering my options to change it.
I have a couple other parts trucks with manual steering boxes in them, but I am thinking if I am going to the trouble why not install power steering.
First picture shows my truck engine. Truck has a 305 from the late 70's in it.
From the searching and reading I have been doing I understand what waterpump I have might be of concern. So what waterpump do I have?
My crank pulley has 3 groves and my water pump pulley has 2 groves. Would I run the power steering belt over both the crank and water pump pulleys?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-27-2008, 05:17 AM   #2
northerngmc
Re: Power Steering Identification help needed
Part 2
When I bought this truck the PO included a power steering pump with the truck.
From the pictures below any idea what it is from?
Will it bolt on?
It seems to need hoses, how hard are they to come by?
Blaine
Old 05-27-2008, 04:45 PM   #3
northerngmc
ttt for the morning crew.....
Blaine
Old 05-27-2008, 08:43 PM   #4
Gulf Rat
Gulf Rat's Avatar
you can use any pump for 72-8X, that steering box will work. Getting the right brackets for pump should be easy, you have the long water pump so just get brackets off an engine with long water pump.
Gulf Rat
Gulf Rat is offline   Reply With Quote
Old 05-27-2008, 08:51 PM   #5
Gulf Rat
Gulf Rat's Avatar
you use the back pulley for your pump also, btw I put PS on my 71 chevy, but it has a short water pump different setup.
Gulf Rat
Old 05-27-2008, 09:18 PM   #6
northerngmc
Gulf Rat
Does that mean I have a short bracket on my steering pump?
Blaine
Last edited by northerngmc; 05-27-2008 at 09:20 PM. Reason: Idot, I need not read it all!
Old 05-27-2008, 09:19 PM   #7
northerngmc
Gulf Rat
Back pulley on the crank pulley? And not on the water pump at all?
Blaine
Old 05-27-2008, 09:34 PM   #8
71/454
Turbo Guy
71/454's Avatar
Man I have this same problem, I'll be watching this thread
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 05-28-2008, 04:05 AM   #9
Sammy
I have no idea what you have going on but from what I encountered. Get from the doner vehicle all the pulleys & brackets. Pwr Str, crank pulley, water pump, pwr gear box & hoses, belts. This way you keep all long pump or short brackets to align everything. One wrong U will be fighting or throwin a belt or cursing something.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-28-2008, 04:06 AM   #10
Sammy
Don't forget pitman arm they are different.
Old 05-28-2008, 03:08 PM   #11
Gulf Rat
Gulf Rat's Avatar
P/S use the back pulley only, yep you have the short water pump bracket on the your P/S pump also the P/S pump is different also. You can still buy both P/S pump rebuild at Auto Parts Stores. Will take some pictures of my setup, and one of a long water pump setup. This is a been their done that for me, on both short and long setup. BTW I think I have a P/S for a long water pump will look tonight.
Gulf Rat
Old 05-29-2008, 04:11 AM   #12
Gulf Rat
Gulf Rat's Avatar
Here's some pic's of a short water pump P/S setup
Name:  truck stuff 001.jpg
Name:  truck stuff 003.jpg
this is on my 71 chevy daily driver soon to have new motor and 5 speed, dropped etc...needs work...lol
Gulf Rat
Old 05-29-2008, 04:48 AM   #13
northerngmc
Thank you very much for the pictures.
Blaine
Old 05-29-2008, 03:31 PM   #14
Gulf Rat
Gulf Rat's Avatar
Hey, found some more info. looks like you have everything but one bracket that bolts to motor.
hope this helps out
Gulf Rat
