05-27-2008, 06:54 PM | #1 |
Rear brakes
'81 Silverado 1/2 ton 2 w/d.....The rear resevoir on my master went dry due to leaky wheel cyl. Cleaned everything up, replaced the parts, now can't get the rear lines to bleed out air. At least the fluid is not lowering after about 4 or 5 attempts. Am I not giving it enough time, or do I have to bench bleed the master cyl? Thanks..........
05-27-2008, 08:37 PM | #2 |
Re: Rear brakes
You probably have the proportioning valve "popped". It is a saftey device that cuts the pressure to the leaking side. That way you still have some brakes. Is the brake light on?
Try opening a bleeder to the front brakes and pushing the pedal. When it hits the bottom there should be a "click". That is the valve moving back to center. Open both rear bleeders at that point and allow the system to "gravity bleed". Just be sure that the master cylinder stays full as the fluid runs down. |
05-27-2008, 08:43 PM | #3 |
Re: Rear brakes
Do I "weigh" the pedal down? Or will the system gravity bleed w/ the pedal up?
Thanks for your advice........... |
05-27-2008, 08:53 PM | #4 |
the pollock
Re: Rear brakes
i used a hand bleeder during my axel swap, i left tthe lines disconnected to long so i drained the whole system out like a retard..
so get a hand bleeder and bleed it out it'll take a minute but it worked for me
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
05-27-2008, 10:47 PM | #5 |
Re: Rear brakes
It will just run out one it's own. It takes a while, so don't forget it and let the master cylinder run dry.....or you are starting over.
05-27-2008, 10:56 PM | #6 | |
Robert Olson Transport
Re: Rear brakes
and yes when you change a master or it runs dry its got to be bench bled
05-27-2008, 11:38 PM | #7 |
Re: Rear brakes
Thank-you to ALL for your advice. I will remove the master and bench bleed it. That makes a lot of sense to me now. I bought a "one man brake bleeder from NAPA. It's a neat little check valve w/ vinyl tubing you attach to the bleeder screw. You press the pedal air/fluid exits, when you release, air cannot re-enter.
05-27-2008, 11:57 PM | #8 |
Re: Rear brakes
ive used them again make sure you dont let air in the top you have to keep the master full
welcome to the board and if ya can please post pics of your ride
05-28-2008, 03:45 AM | #9 | |
Re: Rear brakes
If you forget it..... it will run dry, and you will be starting over. |
05-28-2008, 03:54 AM | #10 |
Re: Rear brakes
yeah i guess i read it wrong it is right what longhair said just dont let the master run dry
