Old 05-27-2008, 09:08 PM   #1
Deathtrapgarage
Oil pressure light keeps coming on.
i have a 1962 c-10 with the 235 c.i. inline 6, recently i changed the oil which hadnt been done in a long time i assume due to the thickness and color and now my oil pressure light has been coming on, i believe i put enough oil in it, the only other thing i could think if it has the correct amount of oil would be the oil pump? any ideas? ive been thinking of putting a pressure gauge to check, any body have a good spot to put one on it and where is the oil pump located? new to this truck and dont have a manuel, also how many quarts do these trucks normally take? thanks alot for the help.
Deathtrapgarage is offline   Reply With Quote
Old 05-27-2008, 10:21 PM   #2
62 short step
62 short step's Avatar
Re: Oil pressure light keeps coming on.
Oil pump is in the pan. I guess it should take 5 quarts, but I've never owned a 6 banger.
62 short step is offline   Reply With Quote
Old 05-28-2008, 06:57 AM   #3
greg64
greg64's Avatar
Seems to me there's an oil port on the gallery on the passenger side. You could tee a gauge in there and see what kind of pressure you have. I agree that the 5 quarts sounds about right. You could also tee at the location where your pressure switch picks up from now.
Good luck.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-28-2008, 06:58 AM   #4
Rogue 64
Ol' Blue Viking
What kind of filter?
Not a crappy FRAM I hope.
I had an issue with a filter that dropped my pressure.
Changed the filter and back to good.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 05-28-2008, 07:11 AM   #5
greg64
greg64's Avatar
Rogue, funny you should mention Fram filters. I used to think they were good too. But then I read a writeup a fellow on the net did where he bought every conceivable filter for a small-block Ford. He cut them all apart and examined their construction and how much filter material was present. Turned out the Fram was crap. As I recall, the AC/Delco ones showed the best.
If anyone's interested, I can probably find the writeup again.
Greg
Old 05-28-2008, 09:17 AM   #6
Chevysdominate
Chevysdominate's Avatar
I wouldn't mind see that writeup.
Chevysdominate is offline   Reply With Quote
Old 05-28-2008, 03:31 PM   #7
62 short step
I would like to see it as well.
Old 05-28-2008, 07:51 PM   #8
greg64
greg64's Avatar
Here ya go guys:
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Summary and opinions on a number of filters:
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
It's a good read. Bet you'll never buy another Fram....
Greg
Old 05-28-2008, 07:57 PM   #9
jchav62
1962 C-10
jchav62's Avatar
What weight oil did you put in it... I would assume it takes 5 quarts. Make sure that canister is clean. Maybe something in the oil lines????
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-28-2008, 08:04 PM   #10
greg64
greg64's Avatar
Joe, you just made me think of something.... Deathtrap, where is the pressure switch located on the engine?
Greg
Old 05-28-2008, 08:14 PM   #11
Deathtrapgarage
10w-4 filter cannister was horribly gunked up completely cleaned it and threw in a new filter non fram, and pressure switch not sure ill have to take a look at it.
