Old 05-28-2008, 12:22 AM   #1
steelhorse
steelhorse's Avatar
87 chevy 350
I bought an 87 c10 for the engine and trans.It had a 350 throttle body motor and 700r4 trans.Here is my question, the 87-95 motors all seem to have different heads and intake.Are these heads any good?If not can you use the 55-86 heads and intake,or the later vortec style heads and intake.Im not looking to build a powerhouse motor just a good strong eng in the 350-400 horse area
steelhorse is offline   Reply With Quote
Old 05-28-2008, 06:06 PM   #2
steelhorse
steelhorse's Avatar
Re: 87 chevy 350
Does anybody know where I might find info on this?
Old 05-30-2008, 02:36 AM   #3
JAKES 68GMC
Aluminum slot wheels rule...
Re: 87 chevy 350
87-95 heads suck. I believe they are called whirlport heads and are only good until 4000rpm or so. They don't make good power.
JAKES 68GMC is offline   Reply With Quote
Old 05-30-2008, 05:26 AM   #4
BP68
BP68's Avatar
Re: 87 chevy 350
You can add Vortec heads. I am using a 89 TBI suburban shortblock with a Comp Cams camshaft, 97 model cast iron Vortec heads, and a Edlebrock intake/carb.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 05-30-2008, 05:30 AM   #5
yad
Driving the Thin Blue Line
Re: 87 chevy 350
Yeah, but can you go backwards with the heads. I have an 87-95 roller cam block, and I want to put on 70's model 350 heads. I have the older style intake manifold for the older heads. Will everything work? I know the 87-95 heads are terrible, but blocks seem ok.
yad is offline   Reply With Quote
Old 05-30-2008, 01:33 PM   #6
steelhorse
steelhorse's Avatar
Re: 87 chevy 350
Mine is the non roller block.Im thinking of going with the GM performance vortec heads and an edelbrock intake.
