c-notch question
can anyone tell me how deep the cpp c-notch is and how much maximum clearance can i expect to get ? is it necessary to use the c-notch bumpstops or can I eleminate them for more drop when its aired out?
#2 | |
Re: c-notch question
The CPP notch allows for 3" additional clearance vs. the original lower portion of the frame rail.
Hey thanks for the info scotti that measurment is exactly what i needed to know.
the research ive done points to the cpp notch as being the one of choice around here for quality,fit, price. is this still the case? |
#4 | |
One day...
![]() Join Date: Apr 2008
The fit is good but not perfect. Definitely close enough for what they cost.
thanks for your input scotts62, im gonna be notching and putting in rear bags as the first phase of my project.
#7 | |
One day...
Im gonna use stock trailing arms with c-notch and bags.
My truck now has ECE 4.5/6 drop. my son and I are starting his project in July, its a 61 short bed thats gonna get dropmember and custom rear. Im not sure what to do for the rear any suggestions?? |
#9 | |
One day...
Dropmember rear kit.
PorterBuilt Man Crush
![]() Join Date: Jul 2007
![]() The only way to go is the Dropmember package, this way the front and the rear will match and be balanced without the hassle and fab work. QUOTE=SCOTI;2740624]Dropmember rear kit.[/ ![]()
The 72 will live again |
#13 |
I talked to Nate about the dropmember kit for the 61 . He said he didnt plan on building rear kits for 60-62 since demand would be pretty low.maybe if enough of us needed them he would!
My best options probly a universial 4-link ,maybe ride tech or kp, ill have to check them out |
